Rotor bolts
[Closed] Rotor bolts
[#242077]
Hi all.
Has anyone used a Dremel to drill out a rounded off rotor bolt? I've got a drill but i don't think i've got a small enough bit, any idea what size i would need? Was thinking 2 or 3mm.
Dave
Posted : 25/01/2009 11:32 am
Use a hacksaw to make a groove across the top of the rounded rotor bolt, then use a screwdriver to remove.
Posted : 25/01/2009 11:36 am
I will give that a try.
Thanks
Posted : 25/01/2009 11:39 am
You're better off filing a bit of a flat onto 2 sides then using a pair of molegrips/stilsons with the teeth in good nick. IME.
Posted : 25/01/2009 11:49 am
If they are hex heads you can usually tap in a slightly larger Torx bit & get enough purchase to slacken them
Worth trying before you resort to cutting tools
Posted : 25/01/2009 11:52 am
i used an angle grinder 😳
Posted : 25/01/2009 12:32 pm
There's only one way to do it proper like.
Posted : 25/01/2009 1:17 pm
