Rotor 3d cranks and...
[Closed] Rotor 3d cranks and bb92
[#10791316]
I have just purchased a Trek checkpoint that has a bb92 BB and comes with a Shimano double Crankset which I have removed
I have a rotor 3D xc3 which I thought would be a simple swap and allow me to run a single ring but once installed there is too much free play even with the preload cap full tightened
Does anyone have any ideas what I am doing wrong? I could get some spacers but this will alter the chainline or make the arms uneven?
Posted : 01/09/2019 5:34 pm
Are you sure the Trek is BB92?
BB92 is a MTB BB, whereas a "Shimano double Crankset" sounds like a road chainset, so will be designed for a narrower BB (as in BB86)
If the frame/BB is actually BB86 then you'll need to add spacers to make a MTB chainset fit.
Posted : 01/09/2019 6:24 pm
What reggie said.
Posted : 01/09/2019 6:28 pm
Thanks for the replies
Trek list the bikes as having a Shimano RS500, 92 mm, PressFit
But the frameset for the same bike is listed as 86.5mm
When I measure it seems to be 92 or 90
Do you mean spacers on the crank spindle or is there a way to add spacers to the bb like you can with a threaded BB?
Posted : 01/09/2019 8:39 pm
The bearings are push-fit you can't add spacers - add spacers to either side of the spindle them to keep the spacing even / chainline correct.
Posted : 01/09/2019 9:12 pm
+1 add spacers to the crank axle.
Yes you'll change the chainline and/or crank arm position, depending on which side you add the spacers but we're talking about 3mm each side, I suspect, so the world won't end.
You can't have it both ways. MTB chainsets are wider than road. That's just the way it is.
Having said that, you could attempt to re-adjust the chainline if you're prepared to tweak the chainring position with spacers.
Posted : 02/09/2019 4:04 pm
