Rohloff replacement...
[Closed] Rohloff replacement cables
[#2941444]
Do I get [url= http://www.sjscycles.co.uk/thorn-gear-cable-set-for-bikes-with-rohloff-14-speed-hub-prod14816/ ]thorn's own set with 1.1m cables, outers and ferules[/url] for £15
Or [url= http://www.sjscycles.co.uk/rohloff-shifter-cables-and-nylon-liner-18-m-for-rohloff-speedhub-500-14-8581-prod16489/ ]1.8m Rohloff cables[/url] for £8 with a set of [url= http://www.sjscycles.co.uk/rohloff-shifter-cable-housing-cap-set-8703-prod16491/ ]Rohloff ferules[/url] for another £5
Posted : 13/07/2011 2:56 pm
rohloff
Posted : 13/07/2011 4:28 pm
thats what seems sensible. cheaper and "genuine" brand.
I've emailed SJS to ask what the difference is...
Posted : 13/07/2011 4:49 pm
Rohloff's just need good quality brake cable outer and a gear cable inner. Those kits *might* be cheaper than buying the constituent parts but I don't fit Rohloff's supplied cables as they seem ridiculously heavy and inflexible.
I think our bulk cable is Transfil at the moment - works well.
Posted : 13/07/2011 5:05 pm
Agreed - I just used standard gear cables, as for derailleurs
Posted : 13/07/2011 5:52 pm
Yep, that works. However, brake cable is stronger - gear outer needs to (can't think of word) not change length when you bend it in order for indexing to work. As Rohloffs are pull pull you can use normal coiled outers (ie Brake) which is tougher (and no more expensive)
Posted : 14/07/2011 7:51 pm
I use whatever it is Thorn/SJS fit to their bikes and they are still working fine after 5 years. Have a look on the Thorn forums you should find plenty of advice there.
Posted : 14/07/2011 8:24 pm
Bought the Thorn set, they're Transfil.
Posted : 15/07/2011 9:51 am
The reason you can use brake outer on a Rohloff is that the indexing takes place inside the hub not at the shifter .
Posted : 15/07/2011 12:37 pm
