rohloff problem
[Closed] rohloff problem
[#3558830]
here's one for the rohloff users..
a while back i converted (or at least my lbs did) one of my scales to a rohloff. ever since it's had a lovely and rather unhelpful habit of shedding the chain. fiddled about with the tensioner, got a wider bottom bracket - no joy.
up round loch tay today, nothing remotely technical and the chain was off an uninspiring five times. are some bikes incompatible with rohloffs. as it is i feel like i've got a very un-necessary commuter.
opinions please
Posted : 12/01/2012 10:51 pm
Sounds like chainline and chain length need to be considered - doesnt sound like a rohloff fault to me
What size is your rear sprocket - i wouldnt go less than a 16 tooth if running a tensioner !
Posted : 12/01/2012 10:55 pm
Just your chainline is wrong.
Dont forget that the rohloff has a 54mm chainline, which is effectively the outer ring position on an mtb chainset.
Posted : 12/01/2012 10:56 pm
Flexy stays?
Helps with feel and no problem with derailleurs, but can sometimes flex too much for a single chainline.
Also is it a singlespeed front ring, or are you still using a derailleur front ring (designed to shed chains)?
Otherwise as above.
Posted : 12/01/2012 10:57 pm
i think the chainline is okay but the front ring...? i must go and check that. cheers
Posted : 13/01/2012 12:44 am
