normal or straight ...
[Closed] normal or straight laced wheels?
[#3558849]
A friend is after a new set of wheels of his enduro. He will have to re use the front hub as 25mm Maxle.
straight laced is £40 more expensive. What are the advantages and is it worth the difference.
He is looking at these, any opinions?
http://www.bikeradar.com/gear/category/components/wheel-sets/product/review-hope-pro-ii-on-mavic-xc717-wheelset-09-34686=
Thanks,
Posted : 12/01/2012 10:58 pm
I had normal and snapped the rear spokes with annoying regularity
Have SP (straight pull) now and they are stiffer, stay truer and have not snapped (or felt like snapping a spoke) in 2 years so if it's a wheelset you'll give some hammer to then i'd say yes the extra is worth it.
Hope that helps
Posted : 12/01/2012 11:04 pm
Yes I will let him know thanks
Posted : 12/01/2012 11:34 pm
SP look cooler too. FWIW I have Pro3 XC6 with SP spokes, needed tightening after 3 months but now very stiff and straight.
Posted : 12/01/2012 11:37 pm
Millions use regular spokes not straight pull, no benefit to latter.
It's your mate's money tho.
Posted : 13/01/2012 12:10 am
crows foot, because it looks ace
Posted : 13/01/2012 12:13 am
what al said.
Posted : 13/01/2012 12:27 am
Cheapo spokes snap regardless of whether they're straight-pull or not, straight ones are rarely available off the shelf in an emergency(got a customer who may be looking at a 2month wait for Shimano ones), though you will have two spares supplied with Hope wheelsets.
Posted : 13/01/2012 9:32 am
Hang on...re-using front hub...do you mean radial lacing...on one side only?
I'm confused.
Posted : 13/01/2012 9:36 am
That hope one in the link will be using J (regular type run of the mill easy to get hold of spokes) in a standard 3 cross pattern.
You can get hope hoops with strait pull spokes that come in a 3 cross ??? build but as others have said spokes are harder to get hold of.
I would not think radial lacing the front wheel would be a good idea (going strait from hub to rim with no crosses of spokes)
Posted : 13/01/2012 9:57 am
Front hub will be laced as it was with new spokes and rim. the question was really about the rear but link shows a pair.
Thanks
Posted : 13/01/2012 12:50 pm
Not really convinced of the advantages but the disadvantages of straight pull- ie, not being able to easily find replacements- are potentially a big deal. I ended up doing a day at fort william on a failing wheel because no shop in the area had a single straightpull. Would have been a 10-minute job in the first shop if it'd been a J.
People talk about removing the "weak spot" at the J- but how often do you break a spoke there?
Posted : 13/01/2012 1:10 pm
[s]crows foot[/s] snow flake, because it looks ace
Posted : 13/01/2012 1:16 pm
if you are talking about radial lacing - it is bad practice to relace a hub with a new pattern. the spokes bed in and will have recesses to sit in. you'll see this if you strip the wheel.
EDIT: oops read the thread now 😳
Posted : 13/01/2012 1:45 pm
Straight pull a nightmare for replacements. I'd avoid at all costs in future.
Cheap spokes fail, badly built wheels break spokes (uneven tension).
Posted : 13/01/2012 1:56 pm
as cynic-al sez - "millions use normal"
go for straight pull they look and feel better
Posted : 14/01/2012 7:03 pm
For all the SP users that are worrying about spokes snapping and not being able to get hold of spares in a hurry, why not just order a few extra when you get the wheels and keep them in your kit bag/car/tool box for if the time arrives? It's what I do, but I'm yet to snap a spoke ever.
Posted : 14/01/2012 7:08 pm
patriotpro -
Member
go for straight pull they...feel better
A classic.
My "BS of the week" thread will return 😛
Posted : 14/01/2012 7:36 pm
problem cynic?
Posted : 14/01/2012 10:29 pm
As Blazing says - good simple advice that you wouldn't think needed saying but alas...;)
Posted : 14/01/2012 11:01 pm
Blazin-saddles - Member
Mine are in my toolkit. Not much use if it happens some time when I don't have my toolkit. I took some to france but if I'd broken 3 spokes, I'd have been foobered.
Carrying spares is fine but it's not as good as not carrying spares.
Posted : 14/01/2012 11:47 pm
it can be a long wait for a replacement straight pull, but if one broke you could just straighten a normal spoke using some pliers and lace it up as an interim measure.
Posted : 15/01/2012 10:49 pm
FWIW straight pull hubs are IME more dished and hence weaker.
Posted : 15/01/2012 10:53 pm
