rohloff on a standa...
[Closed] rohloff on a standard dropout?
 ton
[#6673237]
would it be possible to run a rohloff on my surly disc trucker.
it has standard dropouts,
Posted : 30/11/2014 9:04 pm
Absolutely, you'll just need to use the chain tensioner.
Posted : 30/11/2014 9:10 pm
 ton
bencooper, like this? no oem plates or anything else
Posted : 30/11/2014 9:19 pm
You'll need a Rohloff Speedbone and the corresponding axle plate, which look like this;
And the whole thing will end up looking like this;
Yes, other side you'll need the OEM2 plate and Speedbone or Monkeybone - in your pic I presume they're using the Monkeybone. Generally neater that way.
Would it be against the rules to say that I still do a STW subscriber discount? 😉
Posted : 30/11/2014 9:23 pm
Needless to say, you don't have to use a Rohloff tensioner.
Other tensioners are available at about 1/3 the price.
This is the Gusset tensioner on our tandem.
[img] ?oh=727431c6e08156c0de61db9c535c4371&oe=5516B5A0[/img]
Posted : 30/11/2014 9:24 pm
 ton
http://cyclemonkeylab.blogspot.co.uk/2013/04/rohloff-equipped-surly-disc-trucker.html
like this
Oh yes, I forgot the Surly dropouts had a hole for the OEM2 plate - so you won't need the Monkeybone or Speedbone, just the OEM2 plate on the Rohloff.
And a tensioner.
Posted : 30/11/2014 9:26 pm
 ton
bencooper, you sell rohloff?
Posted : 30/11/2014 9:27 pm
Yup, do loads of them - over half the bikes I do are Rohloff bikes 😉
Posted : 30/11/2014 9:29 pm
 ton
thanks for your help. i will be in touch.
Posted : 30/11/2014 9:30 pm
No worries 😉
Posted : 30/11/2014 9:32 pm
