Does any one know the recomenned weight range for the different springs for coil front shocks thanks
[url= http://www.sram.com/_media/pdf/service/coil_spring_chart.pdf ]look on the rockshox website[/url]
Thanks will do
They are a bit optimistic. Give TFTuned a ring.
I'm rated at X-heavy on the RS chart, but heavy is more than enough.....
yeah i weigh 84 kg and dont get more half the travel on my rev and there is no preload on at all. TFT is doing my air revs next week then its the coils turn so i will have a chat with tim first thanks PP
I'm the opposite Handyman (if you're using stock spring?). I use too much of the travel too easily. Have to use the lockout dial about half way round - just cant be arsed speding £40 on a spring.
