Rockshox sektor dua...
[Closed] Rockshox sektor dual position coil
[#4099430]
Has anyone used these forks mainly in the short travel 120mm setting for most of the time. Was thinking of converting my air sektors to dp coil to go on my cotic bfe but not sure if the short travel setting is only meant as a climbing aid or do they work just as well in both positions. Thanks
Posted : 25/06/2012 12:06 am
You can fit spacers to the air forks to drop the travel (unless you actually want the coil which is disproportionally expensive to buy after-market).
Posted : 25/06/2012 12:14 am
Ive already dropped the travel to 120mm with spacers but like the idea of being able to quickly change the travel back to 150mm, might speak to loco in the morning
Posted : 25/06/2012 12:20 am
