Rockshox Rev's...
[Closed] Rockshox Rev's 2010 U turn travel packing down / dropping causes ?
[#1547553]
When the forks are wound out to 150 full travel following a rocky descent. The forks seem to be packing down/dropping travel down to 120. + and - pressures seem fine.
Any advice possible causes ?
Posted : 26/04/2010 7:52 pm
Could be the same issue that's been discussed over on mtbr.com for some time concerning the 2010 U-Turn Revs. The factory acknowledged it as an issue and repairs are being done under warranty. Worth doing a search over there I suspect.
Posted : 26/04/2010 7:54 pm
Thanks will have a look over there
Posted : 26/04/2010 8:01 pm
Had the same. Fork would drop to 120mm at the first sign of a bump. U-Turn cylinder replaced under warranty and no problems since.
Posted : 26/04/2010 8:06 pm
Schweiz who did you go through for the repair the supplier/shop ?
Posted : 26/04/2010 8:20 pm
Shop, although my forks were only a few hours old at the time. Turn around was approx 4 days.
Posted : 26/04/2010 8:50 pm
My u-turn cylinder has just failed for the second time with a pop, almost throwing me over the bars on a set of steps.
Trying to decide whether to try another warranty repair or get my money back and get a real fork (Talas). Tending towards the "not fit for purpose" route....
Posted : 05/05/2010 10:05 am
