Rockshox Reverb ser...
[Closed] Rockshox Reverb servicing.
[#4313123]
The return speed on mine is ridiculous and I think it needs a service. I'm not confident doing this myself and wondered if anyone had any recommendations of where I could have this done without being ripped off.
Posted : 30/08/2012 10:10 pm
Take it you have checked the air pressure? 🙂
I took delivery of a shiny new one for my Solaris yesterday and thought it was knackered due to slow return speed, turned out it had very little air in it 🙂
Alan.
Posted : 30/08/2012 10:13 pm
Nope - not given that a thought tbh. Easy to do?
Ta. 🙂
Posted : 30/08/2012 10:14 pm
Take out of bike, unscrew wee air cap on the bottom, screw on pump, charge to 200 psi, done.
Posted : 30/08/2012 10:18 pm
Think i'll check air pressure and failing that a system bleed. Don't fancy messing with seals etc myself though so anything more significant and i'll be finding a service centre I reckon.
[u][b]MAKE SURE IT WORKS, THEN:[/b][/u]
unscrew pump, screw on wee air cap, done 😉
Posted : 30/08/2012 10:21 pm
Wouldn't do that until you've verified that it's worked 😉
Posted : 30/08/2012 10:22 pm
Thanks guys. Never examined it save for sticking it in the bike and riding it 😳
I'll be sure to check it works first.
Posted : 30/08/2012 10:28 pm
If it's not the air, it'll just want bled. Did the bleed kit come with it? If so, just follow the video on the Sram website.
Posted : 30/08/2012 11:32 pm
A bleed might be in order.. Our Reverb can be found below:
http://www.epicbleedsolutions.com/products/bleed-kits/rockshox/reverb/complete-kit/
Posted : 01/09/2012 9:52 am
You posted me one yesterday 😀
Posted : 01/09/2012 9:56 am
The speed issues are related oil ever so slightly leaking over time, most probably from the lever end. As others have said, give it a bleed and pump it up to 250psi and it should return faster.
Posted : 01/09/2012 10:25 am
250 psi - are you supposed to put the air in with the post fully extended?
Stupid question but have you tried adjusting the silver collar on the lever?
Posted : 01/09/2012 2:55 pm
And if it's still not working after all of the above, Loco's now servicing them.
Posted : 01/09/2012 6:11 pm
