Rockshox Reverb Pur...
[Closed] Rockshox Reverb Purchase Query
[#4510109]
Looking at purchasing imminently a Reverb post. Getting a bit confused (which doesn't take much) There's lots of variation in pricing but it seems that all the adverts are not offering the same things.
Im after a 2013 Reverb 30.9 - 420mm - 125mm - LH remote (non MMX) With the height collar and the bleed kit. There's plenty of MMX right hand versions 🙁
What price should I be looking at? would be grateful for a steer in the right direction.
Posted : 30/10/2012 3:48 pm
As far as I know the MMX makes no difference so all you need is LH remote with correct diameter and length for what you need.
Posted : 30/10/2012 3:53 pm
Doesn't the MMX bracket have a plate sticking out on the underside of the clamp?
Posted : 30/10/2012 3:56 pm
its removable so if you want mmx you get rid of the metal lump, if not you use it
Posted : 30/10/2012 3:58 pm
Also, have you considered using a RH remote upside down on the left of the bars? I MUCH prefer it that way.
Just a thought.
Posted : 30/10/2012 4:01 pm
Ah that makes more sense, so its a MMX compatible if you want it.
Thanks for that.
Posted : 30/10/2012 4:02 pm
Cheap at merlin. I'm not sure if it's the exact flavour you want but at just under £200 I'm very very happy with mine.
[url= http://www.merlincycles.com/bike-shop/mtb-parts/saddles-posts-1/seatposts/rockshox-reverb-sale.html ]Linky[/url]
Edit: Yeah, it doesn't come with a bleed kit, but after 2 years of peak, lakes, alps and hebden bridge, my mates is only just showing signs of needing a bleed.
Posted : 30/10/2012 10:03 pm
+ 1 for a RH lever and mount it on the LH side upside down.
If yer tough like me and run 1x9 or 1x10 then it fits sweet where the LH shifter would be.
They are the best thing since sliced bread! 🙂
Posted : 30/10/2012 11:40 pm
