My reverb which is 2 years and 6 months old has just lost all its air and when I try and pump it up it won't hold air.
Is this something a service would fix? is it end user fixable? is it toast?
When I move the post up and down there is some oil being left on the shaft if that means anything.
mine does the same , not had the time to take it appart but one of the o rings is gone . an internal service by a specialist should sort it .
Ring tftuned and explain what's happening. They're honest guys and will hopefully have an idea about what's going on and possible costs if you send it to them.
Almost certainly fixable with a service. It's like a really faffy fork service if you want to do it yourself. Not impossible by any means, but can get sweary. Otherwise probably around £60-ish (based on my LBS) for a shop to do it
