Just about to pull the trigger on a Reverb post as had enough of the Command Post on my Enduro.
Looking to get from Merlin Cycles but i see they only have the MMX version in stock. Will this work with my X9 / Elixir CR shifter and brake combo?
Cheers for the help guys 🙂
I think the MMX is for XX brakes only, but don't quote me on that. I just got the normal mount version. Apparently the MMX extra bit can be left in box and just mount as usual if it dose not fit. I got my post from HIBIKE in Germany, £196 delivered, only took 4 days to arrive, they have all types in stock. I couldn't choose which side it mounted but wasn't fussed, it came as a right hand mount.
The MMX mount is the same as the normal one, just with the MMX bit bolted through for if you plan on using it. If you don't want to, you just unbolt it.
The lever mounts are identical.
If it definitely comes with the standard useable clamp then i may aswell get the MMX version as if i ever decide to upgrade to XX brakes in the future i have the matchmaker clamp. If someone who has actually got the MMX version could comment would be so useful 🙂
@Hob Nob thats great thank you 🙂
Reverb came today the MMX adapter compatable but took that off and used clamp as per standard and it fits perfect. So pleased with it! 10 times smoother than the command post! And love the fact you get the bleed kit and tools etc in the box.
