Rockshox Revelatio...
[Closed] Rockshox Revelation problems
[#3097727]
My 140mm dual air revelation rl forks stick down to around 130mm after being used for a while.
if i let the negative air out then pump them back up they return to full travel. the forks are 6months old and have done this since new.
can anyone explain why this is happening or should i send the forks back on warrenty.
i have got another set of revelation rlt forks and i dont have this problem with these.
Posted : 30/08/2011 8:22 pm
Might be air leaking from the +ve to the -ve chamber? Mine are doing much the same thing, going to send them back while they are still under warranty. It's not a good sign even if they are otherwise working ok.
Posted : 30/08/2011 9:12 pm
