Rockshox red rum? a...
[Closed] Rockshox red rum? alternative?
[#6062024]
Looking for the above.
Seems to be out of stock everywhere,alternative or anyone got any spare?
Thanx,
Max.
Posted : 24/03/2014 9:05 pm
Is that external stuff? I've seen my mate use normal chain lube 😐 risk it if you fancy!
Posted : 24/03/2014 9:40 pm
No,
It's the red oil that you soak the foam rings in to lubricate.
Not sure what I could use as an alternative.
Thanx,
Max
Posted : 24/03/2014 9:53 pm
fox float fluid?
http://www.ebay.co.uk/sch/Cycling-/7294/i.html?_from=R40&_nkw=float+fluid
Posted : 24/03/2014 9:56 pm
I just use the same oil as the lubricant bath. IIRC the Red Rum is supposed to be Torco assembly lube but I don't know that to be true.
Posted : 24/03/2014 9:57 pm
OH! I remember now, Yeh I just used the motul stuff i filled the bath with
Posted : 24/03/2014 10:01 pm
15wt fork oil. Job done. 🙂
Posted : 24/03/2014 10:08 pm
Pft. Gearbox oil in my revs.
Posted : 24/03/2014 10:12 pm
Ok guys,
Mite just use the 15wt as have that for the lower legs.
Posted : 24/03/2014 10:41 pm
Same as the lowers oil as it's going to mix with it as soon as you turn the bike upside down
Posted : 24/03/2014 11:52 pm
