Anybody know where I can get the shaft nut which sits under the rebound adjuster and secures the air spring to the lower leg?
In the process of servicing my forks and need a new one to reassemble.Old one had sheared.
TFT only sell it with the rebound adjuster for £24,and I was hoping someone might have a spare or know where I can source just the nut.
If it's under the rebound adjuster, then it is the bolt that holds the damper assembly to the lower leg, not the air spring....
I'd have thought that this bolt would just be a fairly standard metric bolt though - you should be able to get something comparable from B&Q or a independent hardware shop I'd have thought.
Whoops,yes meant bolt!
Wasn`t sure if it was an standard M8 X 20 or not,or if there was anything which made is RS specific ,so phoned TFT and they have put a spare in the post.
