Rockshox RCT3 probl...
[Closed] Rockshox RCT3 problem!
[#5057286]
Hi,
I am having issues with my RCT3 forks.They are brand new and only been ridden on roads so far.The 3 position dial does not seem to work.When riding with 120psi in the fork (my reccomended pressure) under hard effort I get over 50mm of movement there is no difference between settings.This is a 100mm Sid 29er fork.I have experimented with oil in the damper assembly and have no joy,doesn't make a difference.I know you will tell me to send them back but they were bought from the states !Can Loco help out? Contact email?
Thanks,
Max
Posted : 11/04/2013 4:46 pm
 LoCo
Send them in and we can have a look over them, it'll work out cheaper than return to the states.
Posted : 11/04/2013 5:01 pm
Make sure the plus shaped dial is open all the way before other adjustments. The compression settings may be off and easily fixed.
Posted : 11/04/2013 5:17 pm
Ok Loco,
What's your address? Any idea what mite be wrong?
Thanks,
Max
Posted : 11/04/2013 5:19 pm
Hi Loco,
Found it and just made a booking.
Thanks for the help,
Max
Posted : 11/04/2013 6:08 pm
