Rockshox Pike charg...
Rockshox Pike charger 3 owners , setup advice needed
[#13529099]
I have a new set of Rockshox Pike Ultimate charger 3 forks. They are 130mm travel and fitted to a Tranny Spur. I have set them to 70 PSI which gives me 30% sag. I weigh approx 76kg. There a no tokens fitted. 1 click HSC and LSC set central. Rebound set middle ish. I have ridden them for approx 8hrs and have fettled a bit but can't find a sweet spot. They seem fine on most stuff but over multi roots , rocks etc they feel uncontrolled and pinged me about. I have adjusted the rebound both directions but this has little effect .
So how have people got these setup?
Posted : 25/03/2025 9:00 pm
Just to add . The previous forks were the Pike charger 2 ultimate which I had setup perfectly for this bike.
Posted : 25/03/2025 9:02 pm
I was warned off from buying Charger 3 forks (I was looking at Lyrics) when I wanted something more tunable for a lighter rider than my Helms as being hideously overdamped. Its telling that they just released a 3.1 version...
Posted : 25/03/2025 9:17 pm
@JohnEdward , I have a set of Lyric charger 3 on my other bike and have them set perfect for my riding, but the pike seem to want a different setup.
Biker , thanks I’ll have a look at that article.
Posted : 25/03/2025 10:31 pm
 Jamz
I would have said that 30% sag is way too much. Simply not enough support from the spring.
BTW Rockshox bought out an updated Pike air shaft for Debonair+, it's called the V2. Bigger negative air chamber so more supple off the top. Sounds like that could work well for you.
Posted : 26/03/2025 8:17 am
