Rockshox Oneloc rem...
[Closed] Rockshox Oneloc removal?
[#7669406]
As per title really. Has anyone removed one of these? The default position of the loc is locked out so its not as simple as just removing the lever and cable. I can't find anything on Google. I'm pretty handy and have no problems taking the fork apart if needs be.
Any help appreciated.
Posted : 24/02/2016 8:30 pm
No
Posted : 24/02/2016 8:31 pm
Ben, go forth and multiply.
Posted : 24/02/2016 8:36 pm
I believe you can disconnect the spring, thus leaving it active as default, then replace the top cap. Google should have some video instructions.
Posted : 24/02/2016 8:40 pm
Might as well replace the compression assembly with one of these babies if you don't need the lockout: http://www.novyparts.com/produits-novyparts-suspensions-vtt/splug-bloc-de-compression-hydraulique/
Posted : 24/02/2016 8:59 pm
