rockshox motion con...
[Closed] rockshox motion control DNA
[#5384965]
So i'm trying to get my head around all this info about rockshox's Motion control compression damping
So all the new revs feature the motion control damper DNA and are solo air (used to hate fiddling with the positive/negative chambers on my old revs)
So they have 4 flavours
http://www.sram.com/rockshox/technologies/motion-control-dna
XX, RCT3, RTL and RL
ignoring the XX at the moment as it's out of my range. From what I can work out the only difference between the RCT3 and the others is the RCT3 has got a knob to twiddle for open,threshold and lock. So if it's open it's going to be exactly the same performance wise as the other 2?
But then it says
"RCT3 features an independent adjustment of low speed compression."
so if i'm really only concerned about high speed compression i.e rock garden stuff then this won't matter to me so much
(I must admit my blackbox SID forks are pretty damn good and far better than any other fork i've had)
Posted : 01/08/2013 3:30 pm
Yep from what I understand the RCT3 has separate high and low speed compression circuits. The high speed is not externally adjustable but the low speed is.
The Black Box Motion control is a very similar unit with the dual compression circuits but without the threshold and lock adjuster.
RLT and RL have a single compression circuit.
Posted : 01/08/2013 4:30 pm
cheers!
just a question if the rct3 is worth the extra £££
Posted : 01/08/2013 4:54 pm
Definitely worth it. I upgraded my RL's to the RCT3 damper and it stood up much better in its travel and didnt dive.
Posted : 01/08/2013 5:03 pm
not actually tried the RCT3 damper but I my mate went from RS Sektors R to BBMC Revs and noticed a vast difference even in the wide open setting.
Posted : 01/08/2013 10:30 pm
michaelonabicycle - Member
What was involved inthe upgrade, Michael? I always thought it wouldn't be cost effective to do that as the rebound damper needed upgrading to Dual Flow at the same time?
Posted : 01/08/2013 10:37 pm
 LoCo
2012 onwards Revelations with the DNA mocos all have the dual flow rebound assm.
2014 Revelations have the Rapid recovery rebound system that a bit different.
Posted : 01/08/2013 10:39 pm
The compression damper part of the RCT3 damper is different to the old one. It actually employs a kind of shim stack, and the standard compression
Depending on circumstances, you might want a relatively open HSC (high speed compression - for your rock garden) but more of a closed LSC circuit to avoid diving into corners etc. Only the RCT3 allows you to adjust this, and in my experience it works well and is a step up from the RLC damper.
But all the posher Rev dampers (including 2012 onwards dual flow etc) are way ahead of the cheaper dampers found in Sektors and pre-2011 forks.
The XX is actually a more basic damper, but it's lighter.
Posted : 01/08/2013 10:47 pm
LoCo - Member
So I can just bang a 2012 RCT3 damper in my RLs?
Posted : 01/08/2013 11:22 pm
yep should be a pretty simple job too.
Posted : 01/08/2013 11:36 pm
So - if I was to do that - could I stick the RL damper in my mart's Coil Sektor R?
Posted : 02/08/2013 8:30 am
 LoCo
@george yes on both counts, however the RL cart will work better with the dual flow rebound assm.
Posted : 02/08/2013 9:17 am
Thanks Loco - have sent you an email for pricing.
Posted : 02/08/2013 9:34 am
I suppose there's no mileage in buying a sektor from planet x and fitting an RCT3 cart?]
what's the RCT3 cart.. £145?
Posted : 02/08/2013 2:31 pm
 LoCo
No point in fitting an RCT3 with a standard rebound assm. as you will still get the packing down on repeated hits and other issue with that match. With a sektor RL it's best to replace the rebound assm for dual flow one.
RCT3 comp. dampers are £125 (rrp £164 ish)
Posted : 02/08/2013 2:35 pm
so might as well look for revs rct3 (planet x sold out of 1 1/8 🙁
Posted : 02/08/2013 2:39 pm
