hi all,
I recently changed from a fox rp23 to a Rockshox monarch Rl on my yeti asr-c because the shock was dead.
I simply transferred the hardware from the fox to the Rockshox, but to start with it was a bit stiff but has now loosened up.
However it still doesn't move much over the small bump stuff like stones etc. if I get a whole new set of hardware will this get the shock moving better?
Ive tried different pressures and rebound settings as well which made no real difference apart from making it bottom out!
How's the tune compared to the old one? New hardware will make near enough no difference unless there's something really wrong with the old stuff.
New hardware no, but you may want to invest in the debonair upgrade..
http://www.bikeradar.com/mtb/gear/category/components/rear-shocks/product/review-rockshox-monarch-debonair-shock-sleeve-upgrade-14-48907/
Err what new hardware, are we talking about? if you talking about mountings, then nope, ain gunna help.
As above, does the new shock have same tune(?).. and you can replace the std can with a debonair can, that is optimised to help with stiction fighting, & initial movement. Supposedly great if you within the normal weight range.. it's not so good with clydesdale sized rider, same as the Fox HV shocks.
PS: I might be interested in your low volume can, as my debonair one is a little too active, with me being of a bigger persuasion
Im not 100% certain but i think the fox was running at about 140 psi but im running the rockshox at just 110 psi and thats feeling quite solid. When i fitted the hardware (mountings) it was really tight to get them in which is why i thought it was that making the movement restricted.
was the fox a HV or LV shock?
Sorry.. in english?? What does that mean?
your RP23 can have a large volume air can which tend to take more airpressure than standard volume air cans. if your RP23 is a large voume air can then it will have significant differences to the small volume monarch. The other thing is that monarch shocks tend to have more damping for the same tune as fox do. are you getting the same amount of travel as you did with the fox?
I've just had a monarch RL serviced by TF tunned.
While they were doing it i asked if the small bump sensitivity could be improved and they have added a reducer into the air can. I'm now running a fraction less pressure, with the same sag settings, but getting better small bump sensitivity.
Its still working well all the way down the stroke as well.
This is a 150mm giant reign
As well as being low or high volume
Shocks come with different tuning setups
Usually either high medium or low compression and high medium or low rebound
For example this high volume monarch has medium reboum, (red) and medium compression (blue)[img]
[/img]
This fox shock has a low compression tune
And a medium rebound
[img]
[/img]
Ah ok. No the fox was just a standard sized air can, very similar to that of the monarch. I am now getting more travel than i was with the rp23, but the rp23 was very tired and needed replacing because the nitrogen had leaked
Ive never even noticed that! I will have to take a look!
Ok so this evening ive had a gander and found the markings. I have a red m and a blue s. Does that mean medium rebound and slow compression??
