Rockshox Fork Sag M...
[Closed] Rockshox Fork Sag Markings
[#12037725]
Are the 150 and 160 forks the same but with different air shaft, fork markings wise ? I want a 150 but wondering if a 160 will do and change the air shaft ?
Posted : 15/09/2021 10:50 pm
All the info you need is on page 7 / 8 for debonair upgrade which covers most of the newest forks.
Likely can just change the air shaft.
Posted : 15/09/2021 10:53 pm
Guessing Lyrik or Yari, so yes 160 can be switched down to 150 no problem.
Posted : 15/09/2021 11:12 pm
I appreciate I can change the air shaft, but wondered whether there was a thing with sag makings ie. forks go 130/140 150/160 170/180, just makes setting up easier.
Posted : 15/09/2021 11:13 pm
My (as purchased) 2020 150mm Lyriks have sag markers for 160mm also if that helps.
Posted : 15/09/2021 11:41 pm
Yes, they’re all the same. My Pikes were 130mm with 130/140 sag markings but nowadays I’ve got them fitted with a 150mm air shaft.
Posted : 16/09/2021 12:01 am
Just ignore the sag markings.
Posted : 16/09/2021 1:55 am
It would have helped if Id posted the link to the PDF!
I wouldn't worry about the sag markers.
Posted : 16/09/2021 9:02 am
“ I wouldn’t worry about the sag markers.”
They can still be useful though - the 25% sag line at 140mm is in the exact same position as where 30% sag would be at 150mm, and the 20% @ 140mm and 25% @ 150mm lines are only 0.5mm apart.
Posted : 16/09/2021 11:21 am
