I've just serviced my dual air revelations and the negative chamber is not holding air when I try to inflate it. The dust seal pops off when the pressure starts to build. The positive chamber holds air ok so I imagine the o-rings are fine. I'm guessing the seal on the 'base plate' on the bottom of the air shaft is letting air through somehow.
Anyone had a similar issue or know what the problem could be?
Is it just the wavy washer and flat washer that seals the bottom of the negative chamber?
Posted : 13/11/2014 11:15 pm
Yes on a set of 2010's I think. 1 seal was wrong, the manual was crap but a call to the importer helped.
Posted : 13/11/2014 11:18 pm
