Rockshox domain tun...
[Closed] Rockshox domain tuning
[#5440525]
Hi Ive been using some domain 302s that I bought 2nd hand. I'm guessing that the spring needs changing as im just slightly under 15st an they seem a bit soft. But I did hear that changing the oil weights and amounts may help. Have tried searching but can't find much.
Also when it gets really rough when riding they make a clicking noise. Which is slightly more than cables banging on frame or that kind of thing. It's not the forks bottoming out I don't think.
Cheers in advance
Posted : 20/08/2013 7:14 am
mission control damper? Got a cheap ratty one you can shove in for £25
Posted : 20/08/2013 7:30 am
Does it have to be out of a domain or will any others fit. If it has to be domain will a 180mm travel go in a 160mm
Posted : 20/08/2013 7:45 am
its from a lyrik (160mm lyrik and 160mm domain are the same bar stanchions being steel)
Posted : 20/08/2013 7:47 am
O rite ok so I'm after one from lyriks then
Posted : 20/08/2013 7:50 am
Yes like the one on offer. The clicking is the spring inside the sanction
Posted : 20/08/2013 8:03 am
Ha ha I misread your reply from earlier. I thought u said get 1 not you have got one. Where abouts are you based
Posted : 20/08/2013 8:25 am
Will a Lyrik damper fit a Domain? I don't think it will. The inner diameter of alu-stanchioned forks is usually narrower than steel ones. That was always the case with RS's 32mm stanchion forks. Could be wrong about the bigger ones though.
Posted : 20/08/2013 9:00 am
You might be able to get a Motion Control damper if yours doesn't have that.
I'm sure TF Tuned told me the MoCo damper was the best you could do in a Domain, so I bought a Totem.
Posted : 20/08/2013 9:09 am
No mine only have rebound control that is all. I had heard about this before but not a clue what fits. If I'm honest I'd buy some fox or lyriks if I could find some 1 to buy my rebas an my domains
Posted : 20/08/2013 9:27 am
 LoCo
From memory the moco is best damper you can fit as threads are different ( can tune the shim stack on mocks too 😉 ) Micos don't work that well with standard rebound dampers anyway even if they do fit
Posted : 20/08/2013 9:32 am
Ok so I'm after a motion control damper them would that have to be out of some domains
Posted : 20/08/2013 9:39 am
