rockshox bush remov...
[Closed] rockshox bush removal from fork lowers
[#4698268]
is there a tool i can buy to pull the old bushes out and press new ones in ? I'm struggling to find either online
i can i suppose use a 32mm washer with a slotted centre hole attached to a bar to pull them out but then need a tool to press the replacements in
Any ideas or is it suspension shop only 'stuff' ?
Posted : 31/12/2012 4:01 pm
Forget it.
For a start, it's not just a matter of installing a new bush! It needs to be 'sized' to your stanchion as well or you'll have a lot of play or it'll knacker your stanchions
I doubt you'll want to pay hundreds of pounds for the tools when it can be done by TFTuned or LoCo for £80-ish
I very much doubt if there's any shops that can do it either. Most just send away to one of the above. 🙂
Posted : 31/12/2012 4:20 pm
As above.Tools are available, but costing around £400 from memory,need a lot of use to warrant buying one.
Posted : 31/12/2012 7:22 pm
What forks are they for? If they have the power bulge Rockshox will say replace the whole lower, loco or TF Tuned could probably replace.
I spoke to SRAM Tech and they replaced my lowers free of charge as it should be a lifetime item
Posted : 31/12/2012 8:42 pm
