Rockbros AS1 Pro el...
Rockbros AS1 Pro electric mini pump
[#13420899]
Anyone one got this particular model
https://rockbrossport.co.uk/products/rockbros-mini-electric-air-pump-as1-pro-120-psi-battery-life-upgraded
What are they like, according to their website it should be able to do 80 psi 4 times on one charge which should be good for 4  inflations of my road bikes 28mm tyres (80 psi) 6 inflations for the gravel bike (55psi) and 10 inflations on the e-mtb (30psi) although ill take that with a pinch of salt until i do some real world tests
Looking to ditch a large collection of Co2 and mini pumps which are spread out on 7 different bikes within our household and just have one pump device to be used on every bike if there is a puncture out on a ride, im the only person who maintains the bikes and fixes any punctures roadside in our household so only need one pump device
Posted : 20/10/2024 10:20 am
I'm very sceptical of that, do they make that claim and what size tyre do they refer to?
I see the attraction of a rechargeable pump but to date have not been convinced to give up on a manual pump with an inexhaustible supply of air and a CO2 just in case a bead needs reseating.
Posted : 20/10/2024 10:39 am
b33k34 and b33k34 reacted
I get good results from standard pumps, even in the rare occasion I puncture (and I'm running tubes). It's another thing to charge, and what happens if not charged for ages, and you realise it's flat.
Posted : 20/10/2024 10:42 am
 FOG
Merlin sell the wonderfully named FumpaPumpa which looks pretty similar. It claims to be able to inflate two road tyres per charge though it is more money. I think I will stick with manual inflation,!
Posted : 20/10/2024 11:22 am
I’m very sceptical of that, do they make that claim and what size tyre do they refer to?
No tyre sizes mentioned hence why i said ill take it with a pinch of salt until real world testing
Not fussed by another thing to charge, everything is rechargable these days, lights, di2, AXS, helmet cam, Garmin, Headphones, Phone, so one more thing makes no difference to me personally
I have no issue using a pump but they still are a pain to use esp when the weather is rubbish and or its dark , you are in a rush and end up snapping/damaging the valve
Will check out the Merlin one
Posted : 20/10/2024 12:38 pm
The big issue is not how well they work, but whether they are gonna work when needed.
Although, I guess it’s the same as Di2.
A friend has one of those type of pumps, couldn’t tell you the brand. He seems pleased with it. As for not working when you need it, I’ve had that a few times with rarely used frame mounted pumps not working or falling apart.
Posted : 20/10/2024 1:07 pm
£85!
Posted : 20/10/2024 1:50 pm
£85!
Yeah, I’m certain he didn’t pay £85 for one, maybe an Aliexpress gamble cheap one iirc.
Posted : 20/10/2024 2:46 pm
 Haze
One more thing to forget to charge!
Posted : 20/10/2024 2:50 pm
This is the other problem with having 7 bikes in the household that have pumps and Co2, having to periodically check each pump is still working and dosent have any issues through lack of use and being strapped to a bike ridden in all weathers
Not really, charge once purchased, then just charge after each use or if not used then check the state of charge every couple of months, no different to DI2, AXS, i weekly charge my headphones and their case, Garmin, helmet cam, smart watch etc.. so one more device isnt an issue
Posted : 20/10/2024 3:17 pm
I bought one of these
https://www.amazon.co.uk/gp/aw/d/B0CL5YG3TW?psc=1&ref=ppx_pop_mob_b_asin_title
It's larger than that rockbros pump, but it comes with a decent frame storage bag. It'll pump up a 2.3 inch wide  29er mtb tyre from flat to 22psi 7 times before running out of juice. I haven't needed to use it much, but it has always worked when I have needed it.
Edit: link isn't working, try this
/a>
Posted : 20/10/2024 3:35 pm
The thing about normal pumps, is that they don't need refilling with anything, other than air, which you can do with your arm.
After dabbling with co2 I went back to pumps because of this reason. Onve you've used the cartridges you have with you, you are then stuck if you need any more.
I think the same about these electric thingys
Posted : 20/10/2024 4:21 pm
My mountain morph pump is probably over 20 years old (saying that, I think it was 2002 or 3 when I bought it) and it sits in a bag...it works every single time I need to use it (less than 10 times a year). It never gets maintained or dried, it goes back in a bag and left until the next time.im absolutely all for electronic solutions - but I prefer them to be better or more practical than the acoustic version...axs absolutely meets that. This pump doesn't do it for me, I'll stick with the Mountain Morph as that has been incredibly dependable.
Posted : 20/10/2024 5:58 pm
I recently bought an electric pump for the car. £20 and added 5psi to 4 car tyres with plenty of charge left.
Doesn't have a presta adaptor but they can be picked up on Ebay for a couple of pounds. It inflates slowly- they all do- so don't expect it to reseat a tyre but for the shed it's a useful toy.
https://amzn.eu/d/anhCXeb
Posted : 20/10/2024 6:19 pm
im absolutely all for electronic solutions – but I prefer them to be better or more practical than the acoustic version
Lighter, much more compact, does road and MTB, doesn't rip valve stems off (TBF neither does the morph but other pumps can be problematic).
The only downside is the limited number of tyres between charges.  Might be an issue on a solo winter epic in Wales, but the other 99% of the year rides are shorter,  clubmates are plentifully, and there's always the broomwagon to call on if all else fails ?.
Posted : 20/10/2024 7:03 pm
Lots of these pumps on alliexpress and a lot cheaper. Ive got 2 branded as cyclami im very impressed with them for the money, less than £30. The bigger of the two i have will easily inflate 4x 29" tyres to 24psi from 0.
Posted : 21/10/2024 11:32 am
After dabbling with co2 I went back to pumps because of this reason. Onve you’ve used the cartridges you have with you, you are then stuck if you need any more.
this is my fear of CO2. A (luckily rare) flat tyre usually means a progression of repair attempts:
1 - add a bit more air to see if it seals on its own
2 - find the hole, put it at the bottom and shake, see if it seals
3 - plug it, try to get it to seal
4 - give up and put a tube in.
how many canisters would I need to guarantee I can get through step 4? Even if step 1 works most of the time.
Posted : 21/10/2024 11:38 am
I'm dubious of anything with a rechargeable battery that isnt replaceable from an unknown brand. Rapidly end up in landfill IME
Posted : 21/10/2024 11:53 am
@escrs - what did you end up buying ?
Im thinking of the cycplus AS2 Pro
Im not sure why there is so much hate for these things? Smaller and lighter than manual pumps, plus you actually can get an accurate tyre pressure
Posted : 05/11/2024 8:30 am
