Rock Shox spares
[Closed] Rock Shox spares
[#2984898]
Hi all I have a set of Tora 302SL front forks, and just went to adjust the U turn Knob on the top left stantion, and it snapped off. Is it possible to replace. I have googled and am struggling, it came as standard on my 98 Specialized FSR XC.
Any help would be greatly appreciated
Marcel
Posted : 26/07/2011 9:00 pm
 nuke
Are they coil? If so...
http://www.chainreactioncycles.com/Models.aspx?ModelID=17670
Says they fit any coil u-turn and it'll be an upgrade over the plastic version on the Toras
If not, give Loco off this forum ( http://www.locotuning.co.uk/) a try...I'm sure he'll sort you out with the right part.
Posted : 26/07/2011 9:09 pm
Its not a U turn as I previously posted but a preload adjuster, Doh.
Posted : 26/07/2011 9:33 pm
These are the kiddies
RockShox Tora 302 SL with 100mm of travel and 32mm Cr-Mo stanchions. Alloy steerer and a Mag lower. Coil spring with preload adjust. Lockout with rebound adjust.
Posted : 26/07/2011 9:53 pm
Google Fishers Outdoor Leisure ltd, search for part no. R5234010. Your LBS should be able to order one for you if they're in stock(public site doesn't carry this info, sorry).
Posted : 26/07/2011 10:27 pm
Think I have found some, have emailed them just to double check, And if they are Happy Daze.
Thanks for the replies and help.
Marcel
Posted : 27/07/2011 9:55 pm
