I'm running a set of Reba sl's, i'm about 85-90kgs and would like some advice on positive and negative air settings to get my forks running right. I like a plush fork without too much bob when out the saddle, usually put lock out on for non techy climbs and hard accelerating out of saddle. Cheers to whoever replies
135psi +
125psi -
See how that feels, hit some big bumps see if you can bottom them out, if not go down in 5 psi increments till you get full travel.
I'm 88kgs and my SLs seem to like this
Cheers mate i'm racing tommorow night and got big peaks ride sun so will give it a go
Set positive and negative chambers to the same pressure for "plusher" feel to the forks. Or lower pressure in -ve chamber to help resist unwanted fork movement (but with more resistance when you do want them to compress).
