Rock shox Pikes, Fi...
[Closed] Rock shox Pikes, Fixed kind off
[#4770514]
So As i said i would i will update you on the progress of the forks.
So i managed to service the forks full seal replacment. inners and outers.
the forks feel plush now.
however my uturn only works for about 1cm. and i seem to have about 145mm travel now which i think is a little od.
Posted : 19/01/2013 5:27 pm
So...
Posted : 19/01/2013 5:29 pm
So any suggestions of a fix or what might have caused this.
Posted : 19/01/2013 5:30 pm
Sounds like you may have got the reassembly slightly wrong. Worth stripping and trying again?
Posted : 19/01/2013 5:34 pm
You!
Posted : 19/01/2013 5:35 pm
Hmm they went back exactly as they came out, but will give that a try. duirdh nobody asked you to coment if you dont want to help,do you have a problem with me or some thing,as i though forums were aplace where people could come and ask for help and advice.
Posted : 19/01/2013 5:40 pm
Is that 145mm of leg showing?
I seem to remember a set of 130mm revs measuring 135mm and they don't use the last bit of travel.
Posted : 19/01/2013 5:44 pm
ye i have it sussed niw though thanks everyone.
Just so people like duridh can take the piss i put the vale in the wrong slot
Posted : 19/01/2013 5:54 pm
Good you got them working - I would be very narked if I had been left in the position you were prior to the fix.
Posted : 19/01/2013 6:05 pm
