I was just given some Rock Shox Pikes which are a little beaten and i dont know much about them.
is there anyway to tell what make/model they are?
well the make is Rock Shox and the model is Pike 😉
but as for which variant probably best to post a picture 🙂
does it matter what the variant is?
also the cap on top are not there, do you know what they are called?
one side is air and the other has a spring if that helps
eh? Well if you want to know what they are then yes.
If they are air then you normally have air in the left leg and a damper (fluid filled) in the right leg.
If they are U-turn (measurements on the left leg) then they will have an adjuster on the top of the right leg and they should have a compression adjuster dial on the right leg.
If they are worse for wear I'd suggest getting them looked at (service wise) before you bother using them.
