Roadies - triple fr...
[Closed] Roadies - triple front mech set-up
[#1482007]
I got a triple (Tiagra 9s) front mech in case I wanted to put on a triple, but will mainly run it with a double.
However it has to sit v high on the seat tube in order to avoid fouling the inner (42T) chainring, I'll give it a whirl but wondered if it is likely to work?
Posted : 06/04/2010 9:53 am
You may need some luck - they make double/triple specific ones after all. Use the orange plastic spacer thing for set up.
Posted : 06/04/2010 9:57 am
But triples are 30-42-52 so should work fine on 42-52 Shirley?
Should point out that despite not having done this set-up before, I am fairly experienced with this sort of thing in general terms.
Posted : 06/04/2010 10:01 am
Will work fine al
Using 42;53 on my road bike with a sora triple no problems
Posted : 06/04/2010 10:18 am
Thanks TR.
Posted : 06/04/2010 10:19 am
Thinking back the problems I had were using a double mech on a triple chainset.
Posted : 06/04/2010 10:20 am
D'Oh!
Posted : 06/04/2010 10:30 am
****. Had a go at setting this mother up.
Seems the c**ts at shimano have made the crank-arm clearance such that my front mech won't work. Oh well back to the 105 cranks I guess...
Anyone want a HT1 D ace crankset?
Posted : 08/04/2010 7:31 pm
Hmmm. Experiencing similar problems with a 108 8s triple c'set, having to set the mech 1/2" above the big ring WTF
Any thoughts?
EDIT I see the tiagra cset is 39-50, p'raps that's why 🙁
Posted : 17/04/2010 4:09 pm
[i]EDIT I see the tiagra cset is 39-50, p'raps that's why[/i]
That's compact isn't it? So surely you could buy a mech for a standard or triple chainset? 105 would be about 25 quid...
Posted : 17/04/2010 4:40 pm
No, it's a triple (I left out the size of the wee ring as it's only the sizes of the outers that is affecting me) and I am running 9s so I am after a 9s front mech...ebay for me!
Posted : 17/04/2010 4:44 pm
