Roadie shifter / dr...
[Closed] Roadie shifter / drivetrain compatibility
 bgd
[#11262950]
I have a five year old cyclocross bike with Tiagra 2x10 shifters and mechs. I have no idea what series they are (can't see any identifying numbers) but I want to replace the shifters with the newer 10 speed Tiagra model but am clueless as to whether they are compatible.
I would have thought so but have read a few things online to say not.
Don't know much about roadie stuff so if anyone could shed some light on this I would be very grateful.
Posted : 23/06/2020 10:47 am
 Aidy
4700 isn't compatible with the other 10-speed components, you'd need a new rear mech too.
Posted : 23/06/2020 10:59 am
 bgd
Thanks for that. I presume front mech too? Would the original cassette still be OK?
Posted : 23/06/2020 11:01 am
 Aidy
front mech should be fine, as should the cassette.
Posted : 23/06/2020 11:04 am
 bgd
Awesome, thanks for the advice
Posted : 23/06/2020 11:07 am
BGD could be interested in the older sti and rear mech if you sell and they are working fine
Posted : 23/06/2020 11:13 am
 bgd
OK, no problem. All work fine, had very little use really. Will give you a shout when I've got it all sorted.
Posted : 23/06/2020 11:15 am
peel back (that is upwards) the hood near to where shifter clamps to bar on outside of shifter the shimano part number should be there....only thing i know on Tiagra compatibility is that at some point it def became the quirky odd one out
Posted : 23/06/2020 11:33 am
 Aidy
Just in case it's of interest, any 11 speed shimano road mech (including the clutch ones) should also work with 4700 over a 10 speed cassette.
Posted : 23/06/2020 11:38 am
Interesting - I have a full Tiagra 2x10 in the spares box. So is it the rear mech that is the limiting factor (non compatible).
Posted : 23/06/2020 12:45 pm
4700 isn’t compatible with the other 10-speed components, you’d need a new rear mech too.
Not entirely true...
Had 4700 rear mech working just fine with 5700 STIs.
Cheers!
I.
Posted : 23/06/2020 12:48 pm
 Aidy
Are you sure it was a 4700? The ratios look like it would undershift massively.
Posted : 23/06/2020 1:12 pm
