Roadie Front Lights...
[Closed] Roadie Front Lights,
Just a bit of a PSA maybe, Cycle Surgery seem to have some very good prices on lights just now. FWIW my own set up at the moment and I've had loads is a bar mounted Smart Polaris light which provides a flashing light so others can see me. I also use an Exposure Joystick mounted on the bars, this I can remove very easily when parked up and it doubles as a helmet light for mtb'in. Provides plenty of usable light for unlit country roads. I've used the ebay lights in the past but for ease of use the above wins hands down, the Smart light lasts ages and the Joystick can be popped of to charge without unwinding cables/velcro straps etc.
Posted : 06/09/2015 1:22 pm
Well I finally bought one. After reading glowing reviews I went for the Cateye Volt 1200, and so far I'm impressed.
In comparison to my XML-L2 Cree torch, it is considerably brighter, the light is much whiter, and the beam has a much better spread. Even if you ignore the unit itself, the actually quality of the light just looks way better. I tested them side by side, and it made the Cree look cheap with a poor beam and hollow blue light.
One of my big concerns was that a few reviews had brought up having to scroll through the flashing mode when changing settings, but it's actually not the case. The flash only mode only activates via a double click, so you just need to make sure you scroll through the modes slowly to avoid it. Would be nice to be able to scroll up or down modes, so you could go from high to low and back again, but it seems to be decent value in comparison to some of the competitors, so I can live with it.
Will see how the mount holds up, but I'm sure I can get a new one if it fails.
The 700 may well have been powerful enough for the road, but one of the deciding factors was the battery life on the 1200.
Posted : 07/11/2015 10:13 pm
Four4ths Scorch job done
http://four4th.co.uk/products/lights/scorch/
Posted : 07/11/2015 11:55 pm
Page 2 / 2
