How do you know you don't have poor levels of perception, what are you basing that on?
I don't, but I do know that even if they're a lot worse than yours, yours still aren't good enough to be able to tell the difference in acceleration.
So knowing my levels of perception so well (better than your own it would appear) what is the weight when I would notice - 5kg, 10kg or would I not even notice if I lost 20kg of weight and rode a 1kg bike?
There simply has to be a point when it is very noticeable with the effect diminishing as you get closer to 1g difference.
To you guys who wouldn't notice a difference in the feel of a bike with 275g wheels I believe you 😀 we're all different, what goes for one doesn't for another. But don't say others can't because I most definitely can, and it improves my enjoyment of a bike.
So Op maybe lighter wheels will work for you maybe they won't. Probably the only way to find out is to spend your money.
[quote=kerley ]So knowing my levels of perception so well (better than your own it would appear) what is the weight when I would notice - 5kg, 10kg or would I not even notice if I lost 20kg of weight and rode a 1kg bike?
I don't think it's that huge assumption that your levels of perception aren't a huge amount better than the norm - if you reckon they are then maybe you need to get on record breakers.
ISTR that the normal limit of human perception for differences is about 5%, hence 2kg difference at the rims (which will be kind of difficult to save off a typical set of road wheels). Though that would be assuming you could keep your power output constant - given that's unlikely then you'd probably need 3kg difference in the rims (or 6kg on the frame) to tell the difference in acceleration.
Of course you would notice the difference if you lost 20kg - you'd fly up the hills - but then we were talking about 300g difference.
[quote=taxi25 ]To you guys who wouldn't notice a difference in the feel of a bike with 275g wheels I believe you we're all different, what goes for one doesn't for another. But don't say others can't because I most definitely can, and it improves my enjoyment of a bike.
You might be able to notice the difference - I've acknowledged that, and expect I might be able to, because it's enough to make the bike feel different as you throw it around. What you won't get is any significant difference in performance, and nor will you be able to tell the difference it makes to your acceleration or the speed at which you climb - if you think you can, that is just placebo effect.
The lighter wheels will feel even better if you give them quality tyres like Veloflex open corsas and latex tubes. Get the tyres for £52 the pair from Ribble.
I think I can tell the difference, certainly whilst racing. Light stiff wheels just pull quicker. My 1100g wheels are light stiff and aero and it shows.
