road tyres and Stan...
[Closed] road tyres and Stans
[#8044231]
I have some wheels set up tubeless with stans and I'm going to fit them to my Kaffenback with Continental 28 c tyres can I put the stans fluid in them and run tubeless like I do on my Maxxis mtb tyres.
Posted : 08/09/2016 10:04 pm
If you're running high pressures I'd suggest the (exorbitantly priced) chunky jizz from stans - "race" IIRR
Posted : 08/09/2016 10:21 pm
 Olly
Short answer, yes. I've got 35c continentals on my surly ghetto tubeless and it seems to work. I am however pretty nervous about burping them. Higher pressure in much smaller space means a burp on a harsher turn might send them from 70,psi to 20psi in an instant and that would be bad news brown pants. Marginally better ride feel, and I've not had a puncture, but i never had as puncture before either. . Probably wouldn' bother doing it in hindsight.
Posted : 08/09/2016 10:25 pm
I think you should be OK. My mate runs his CX tubeless wheels with 'non' tubeless tyres. He's hd no issues for the past year. I guess if they do burp you have no comeback in terms you used something it was not designed for. Its not to say it won't work though.
Posted : 08/09/2016 10:43 pm
Thanks for your help will see how it goes
Posted : 09/09/2016 8:21 am
I personally wouldn't run high pressures in non tubeless tyres. It's one thing at MTB or CX pressures. But on a road bike with a non tubeless tyre you've got a far higher chance of it blowing off. What happens if that's at speed going round a corner or in front of a car?
I wouldn't risk it. There are lots of good road tubeless tyres - schwalbe, hutchinson or my current favourite IRC
Posted : 09/09/2016 8:50 am
Agreed - last thing you want is it blowing off rim whilst cornering at 35mph with a double decker bus coming in the other direction.
Posted : 09/09/2016 9:40 am
+1. Ordinary road tyres are not designed to withstand the pressure generated by running tubeless. I run Schwalbe Pro One tubeless tyres with Stans fluid and Grail rims, and am pretty happy with the set up. I might switch to Hutchinson Sector 28s for winter.
Posted : 09/09/2016 10:47 am
Cheers will look at changing my tyres for tubeless version don't want to have a bad experience for the sake of a few quid. Thanks
Posted : 09/09/2016 2:00 pm
the general advice is that road tubeless should use proper tubeless tyres, as the bead isn't strong enough on std. clincher tyres. The Schwalbe range has some good options; One, Pro One, S-One, G-One etc. which will be fine.
I've actually tried 28mm std GP4Seasons tubeless and they did go up but the sidewalls took ages to seal. I'm on Pro Ones and S-Ones now.
Posted : 09/09/2016 3:02 pm
+1
This is why I bought TLR specific wheels and tyres for my new build (still in progress)
Given how tight the tyres are (F***ing tight + VAT) I'm guessing that non tubeless tyres would be as slack as the security at City Airport.
Posted : 09/09/2016 3:40 pm
