Road triple chain l...
[Closed] Road triple chain line
[#1832878]
Anyone else have an extreme chain line when using the largest two sprockets in the middle ring? Keeps dropping onto the little ring for me.
Posted : 26/07/2010 2:14 pm
nope, have never had that problem.
Posted : 26/07/2010 2:24 pm
Nope, no problems here either, although it does look a bit extreme so I try to avoid using it until I can afford a double chainset to replace it with.
Posted : 26/07/2010 2:57 pm
 hels
I think the key is not to use the largest two sprockets at the back when in the middle ring. Keep your chain straight - who do you think you are - Andy Schleck ??
Posted : 26/07/2010 2:58 pm
Mtfu and get a double. Or man down and get a compact
Posted : 26/07/2010 2:59 pm
yeah mine sometimes drops off onto the 'granny' ring when i'm in the middle ring and largest sproclet. I just stopped using that combo.
Posted : 26/07/2010 3:02 pm
 toab
mine's never dropped but you do have to trim the front derailier a little to keep it happy
Posted : 26/07/2010 3:06 pm
I manned down. You don't need to change the shifter or mech, just set the limits right.
Compacts perfect if you don't have to keep up with a bunch or TT, much better chain line and close enough range of gears for most everywhere.
Posted : 26/07/2010 3:08 pm
Thanks for that pearl of advice.
I'm sticking with triple for various reasons, this is a thread about triple set-up. I do not like compact double.
Posted : 26/07/2010 3:13 pm
Mine did something similar, replaced the BB with one 3mm shorter... works fine now 🙂
Square taper BB, went from a 118 to a 115.
David.
Posted : 26/07/2010 3:54 pm
I've got HT2 outboard bearings, so I can't change the axle length. No spacers on the cups either.
Posted : 26/07/2010 4:04 pm
