Road route (GPX) cr...
[Closed] Road route (GPX) creation.
[#9422478]
What is the current website of choice for creating a road ride GPX to follow with a garmin? I use Garmin Connect generally, but almost every ride now it takes me up/down something entirely unsuitable for a road bike. While I understand this is simply answered by 'get a gnarmac', I'm already dangerously close to the S -1 end of the N +1 equation (and sometimes lead club rides, where some people 'only' have road bikes... *Shudder*).
With Garmin Connect I can choose for it to allow cycle paths, but then it also allows dirt tracks. I'd like to be able to create a route including cycle paths but no 'off road' bits.
Photo giving perfect example of a 'cycle path' according to Garmin.
Posted : 07/07/2017 9:37 am
Strava then Bikehike if you need to convert it to a .gpx track that plays nicely with Garmins
Posted : 07/07/2017 9:42 am
That looks a great cycle path, it's the bike that's the problem 😉
Ridewithgps
Posted : 07/07/2017 9:43 am
 Bez
RideWithGPS FTW. I've planned everything up to a 1500km route with it without any frustration, and I'm a picky sod 🙂
Posted : 07/07/2017 9:50 am
Bikehike is my go to for on & off road.
I think the issue is (with Bikehike anyway) if google maps thinks it's a road. If I'm unsure I'll have a quick look on satellite or street view.
Ridewithgps. It's pretty reliable with google maps, less so if you switch to OSM. I use the streetview icon to check if the plot is all on roads - just hover it over the route you've drawn and check that there are blue lines on all of it.
Posted : 07/07/2017 9:53 am
With bikehike some paths/tracks/lines are treated as roads but others aren't. It uses Google maps for the routing. By default "follow roads" is on so if it suddenly takes a huge detour then undo your last point, turn the "follow roads" option off and click along the route you want to follow until you get back on something that's obviously a road.
Posted : 07/07/2017 9:55 am
Ha, sounds like you're hitting the same snag I'm hitting, in that some cycle paths are perfect tarmac, but others are gravel or fireroad. I use the Strava route plotter but it doesn't make a distinction between tarmac and gravel cycle paths.
Posted : 07/07/2017 9:57 am
 Bez
It uses Google for the route calculation regardless of which map you're viewing. This means that when you view OSM/OCM you'll see a lot of trails which aren't used by Google Maps for routing.
The way I tend to do it is this:
For purely road routes, I view Google Maps and use "Follow roads" with the "Driving" option, which is pretty reliable at keeping you on tarmac. I usually set the start and end points and then drag the route to where I want it (if you let it do its own thing you'll end up on major roads, but at least it won't send you down unsurfaced tracks). If I need to check details I normally have a Google Maps tab open which I can switch to and check Streetview.
For mixed road/off-road routes with the CX bike, I normally view OpenCycleMap and primarily use "Follow roads" with the "Cycling" option, which means Google's routing starts using dirt tracks as well as tarmac. Then when I get to a bit that's visible on OCM but not routable by Google (eg green dashed paths on OCM, which are often bridleways) I switch to "Draw lines" mode and drag the route manually over that section. I tend to have Bing Maps open in another tab so I can check the OS map, which gives a better steer as to what's likely to be easily covered on a CX bike.
For full off-road routes I tend to use mostly "Draw lines" on OCM, switching to "Follow roads" where there's a significant road section, and again I have Bing Maps open in another tab.
All works well for me.
Posted : 07/07/2017 10:11 am
Garmin Connect and use of satellite view where it isn't clear what you're about to follow. Top tip zoom right in on satellite view.
Posted : 07/07/2017 10:25 am
I use gpsies.com and regularly switch to google satellite view if I'm not sure whether the 'road' is actually a rutted farm track.
Posted : 07/07/2017 11:07 am
GPSies. Can switch between numerous maps or satellite. Can upload or download with loads of file formats
Posted : 07/07/2017 11:37 am
http://cycle.travel/
Posted : 07/07/2017 12:19 pm
