Road rear mech help
[Closed] Road rear mech help
[#11759101]
Building a new frame with ultegra 8000 rear mech, I can't get the rear mech to sit close enough towards the wheel for the jockey wheels to line up under the biggest sprocket and on the h adjuster on full it sits to the right of the little sprocket when looking from the rear. Tried a 7000 mech as well same result.
So could it be too long a piece of cable outer from frame to rear mech? I have measured distance from lock ring to inside of drop out and it's 7mm on my hunt rear, but only 4 mm on a prime wheel. But never had this issue before when using the hunts on other frames.
Posted : 17/02/2021 9:00 pm
Disconnect the cable, set the limit screws.
Posted : 17/02/2021 9:09 pm
Too much of a gap with that frame/wheel to the drop out.
Posted : 17/02/2021 9:11 pm
I think it's a wheel drop out issue, does work with cable disconnected
Posted : 17/02/2021 9:13 pm
direct mount vs standard mount rear mech issue?
Posted : 17/02/2021 9:23 pm
How can it be a wheel / dropout issue then?
Posted : 17/02/2021 9:37 pm
sorry typo does not work with cable disconnected
the rear mech hanger sits outside of the drop out, other frames i have with 142 rear the mech hangers tend to be on the inside of the drop out
Posted : 17/02/2021 10:43 pm
some close up pics on the rose website would indicate a direct mount hanger, can i remove the link from my current mech to make it dircet mount?
Posted : 17/02/2021 10:48 pm
Yes, I believe that you can
Posted : 17/02/2021 10:54 pm
this should solve my problem and lots of frustration.
Posted : 17/02/2021 11:03 pm
