Road plus fit in 26...
[Closed] Road plus fit in 26" mtb frame?
[#9778945]
Anyone tried to put the new 650 x 47 setup in a 26" mtb frame and forks? Obviously running discs. I have a lovely 26" frame and forks in my basement. Can't find any measurements on't interweb.
Posted : 18/01/2018 10:50 am
Depends on exact clearances, 47mm might be tight, but chances are it'll fit unless it's a 90s MTB with not much room.
You won't know unitl you get your measuring stick out!
Posted : 18/01/2018 10:58 am
I have a set on my Whyte Glencoe, I will have a go later and let you know.
Posted : 18/01/2018 10:59 am
It's a 2010, I believe mk2 soul with Reba dual air forks (the last best versions) so clearance for 26 x 2.3 tyres easily. I know you could fit 700c in a 26" but the toe overlap was an issue, but that was a 90's frame I tried that in. Road plus is 650c?, so smaller diameter. Do 47c tyres make the overall diameter back up to 700c with say 34 mm tyres on?
Posted : 18/01/2018 12:14 pm
About that.
Posted : 18/01/2018 12:15 pm
I have photo's they aren't working for some reason.
the 650b with 47c tyres do fit into a Clubroost stinger 26" wheeled frame and forks
Posted : 25/01/2018 11:08 am
