Road discs
[Closed] Road discs
[#9400324]
Has anyone made the change to hydraulic discs and regretted it. I'm talking myself into it mainly for improved wet weather performance
Thanks
Posted : 25/06/2017 5:36 pm
Disc Debate Quokka is apprehensive !
[img] https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcR9IQxjqgf54MJaKRr9W_dvINPTT98IWfYPCO8RvXQilSoCYuL3 [/img]
Posted : 25/06/2017 5:43 pm
Slow Loris is worried
Posted : 25/06/2017 5:48 pm
Don't get the entry level shimano lwvers they are awful. The hose entry point sticks straight into the fleshy part of your thumb if you use the hoods
Posted : 25/06/2017 5:49 pm
you'll go over the bar first time you use them, have you got a good dentist ?
Posted : 25/06/2017 5:50 pm
However, if you are using them on flared drops, that puts them in a position that negates the issue.
They're brilliant.
Posted : 25/06/2017 5:54 pm
I have SRAM Levels on my Superfly, which is peforming road bike duties for me until I can afford an actual road bike.
They are the worst thing about the bike. I wouldn't mind so much if I used it as an MTB as I'd appreciate the power and relatively nice lever feel, but for road duties and commuting duties they have been an expensive pain in the eardrum for little actual benefit.
The current state of play is I have reduced the earsplitting noise when braking in the wet to merely 'ear-bothering' noise. I achieved this by trying several compounds and brands of pads, before actually buying a different style and brand (and size) of rotors. I still have some sort of weird resonant moaning vibration from the back brake which travels up the seat post, but I'm just going to have to live with it.
I also spent several hours chasing what I thought was a creak or a mis-aligned front mech, when in actual fact it was a burr in the one of the disc pads which rubbed off the rotor only when I put pressure on the pedals. I've mostly solved this but will need to re-align the callipers again, which is easy enough with a Hayes alignment gauge but is still hit-or-miss compared to re-aligning a road bike calliper.
Why does all this bother me so much? Because on my commute and regular road rides, the discs offer me nothing that I felt I lacked with a decent set of 105 callipers on a bog standard set of OEM wheels. My other commuter has cantis with posh Swisstop pads. Obvs they're not as good as the discs, but they're not as noisy either, and are much easier to keep running rub free etc. I'm swapping to mini-Vs as soon as I can which should improve things a little more.
You need to ask if you *really* feel you'll benefit from discs, and if they're worth the extra money/weight/complication.
Going by their popularity, I'd guess many people think they are, and fair play to them. I'll just continue to make life difficult for myself by trying to emulate a modern all-road/gravel/endurance bike, but with rim brakes. 8)
Posted : 25/06/2017 6:09 pm
Have the Shimano 685 levers and 785 callipers (or is the other way around) on two bikes - one CX and one proper road bike.
The CX was bought deliberately with discs as it's an all weather commuter. The road bike because that particular model had a huge discount in the end of model year sale.
Both are excellent - one finger braking from high speed is lovely - and that's with weedy 140mm rotors.
I can't see any disadvantages other than cost and a (pretty minor) weight increase.
However- when it's dry theres little advantage - but I want to ride my nice bike in the rain when I want to so like the versatility.
Edit- as per above poster yes set up issues can be a pain to resolve as per MTB discs. Not had any issues with the road discs other than getting hydraulic oil on one disc & pad so it was squeally until it was cleaned off thoroughly via hot water, washing up liquid and a hot oven (again same as MTB)
Posted : 25/06/2017 6:14 pm
Have 105 hydros on my Condor. Don't regret it.
Takes a while to adjust to the extra stopping power.
Love the consistency of braking even in the rain.
Love that my wheels and brakes don't turn to a powdery sludgy abrasive gloop any more after wet weather braking.
Love not having that muck all over my hands if I have to fix a puncture.
Haters are gonna hate, and I can see the possibility of me potentially getting a rim braked fancy bike for high days and holidays, but the question was whether I regret and the answer is definitely "no"
Posted : 25/06/2017 6:59 pm
Sram rival hydros on my cx comuter / Road bike dosnt get a look in these days. Can't fault them and certainly no regrets won't bother buying a bike with rim brakes again.
Posted : 25/06/2017 7:04 pm
 aP
I have eTap HRD on my Bokeh, and they're very good. Powerful enough, progressive enough. Rear has started to make a grinding noise today though.
I still ride 600km in Italy on my Chorus rim brake equipped road bike 2 weeks ago, and they were also awesome.
Horses for courses.
105 Hydros here too. Love them, not had any issues with setup or maintenance, they just work and they work well.
Posted : 25/06/2017 7:06 pm
I've only gone half hydro, but yes, wet weather performance is increased. Although I prefer my rim braked bike, and who likes riding in the rain anyway?!
Posted : 25/06/2017 7:11 pm
 igm
As a heavier rider (c) I find the discs really good on longer steeper descents where the calliper brakes struggled after a while - possibly due to heat. In the dry on the flat there isn't much in it.
Posted : 25/06/2017 7:12 pm
The people I passed today seemed to enjoy using them.
Posted : 25/06/2017 7:35 pm
I have Ultegra hydro brakes on my cx and it gets used on the road a lot. It has the shimano ice tec rotors 160mm and it is silent braking wise (apart from the rattle from the internal rear hose)
I would not go back to cable disks - the bike came with trp spyres and the hydro's are so much better
Posted : 25/06/2017 7:45 pm
BR505s on my Cube, if my old Tricross Singlecross had had hydraulic brakes, what happened at ~0645 on 23/12/2013 would have been very different. The stopping power on the Cube is amazing, even descending the cat4 hills I've been climbing recently.
Posted : 25/06/2017 7:49 pm
Ha, so it seems my deep dislike of discs for road use is not due to discs in general, but just SRAM discs in particular.
Why I am I not surprised... 🙄
Posted : 25/06/2017 7:52 pm
No, one disliked Sram, a second liked Sram. I'll add, i love my Sram rival hydros too.
Posted : 25/06/2017 7:59 pm
So you have MTB brakes on an MTB and think that means road brakes are bad? Okay.
I have SRAM HRD brakes on my winter/office bike. Perfectly happy with them, would get disc brakes on a new road bike without hesitation.
Posted : 25/06/2017 8:04 pm
Some mixed feelings with mine (R685).
In the dry the stopping power is great. Genuinely can ride some of the steep twisty lanes (1 5 and steeper) with far more confidence.
After a wet ride, the bike stays remarkably clean - not covered in brake pad gunge.
For me however the ergonomics are woeful (I have Campag on my summer bike). The hoods are very long, so when I have the flats and the drops in the right position, the natural position on the hoods is a bit stretched out.
Secondly, I have relatively small hands for a bloke. Even with the reach adjust would all the way in, I can't actually wrap a finger tip around the lever end from the drops, and then when you try and grab the lever, it just moves sideways out the way, thanks to the shifting setup with the brake lever blade playing double duties. It's liveable with in the summer, but it's a proper issue in big winter gloves. That then leaves the bite point very close to the bars, so there's a lot of lever pull to get through - again an issue in thick gloves, as it's quite possible to get the glove material caught between the bars and the lever and impede the pull.
I also struggle with feel in the wet. The front's not too much of an issue as I can hear what's going on, but it's really difficult to finesse the point between braking and locked on the rear. I've had a couple of moments when I've ended up locking up without realising and nearly gone down as a result. Actually knocked my confidence to ride that hard in the wet, which completely defeats the point of a disced up winter roadie. I'm currently running a 160mm rear disc, Want to drop down to a 140mm to see if I get a bit more modulation out of that.
I've also had issues with contaminated rotors from traffic grime, which can make stopping very unpredictable - actually much worse than rim brakes, as there's absolutely nothing there until you get the rotor hot enough to burn the crap off.
All in all, bit of a mixed bag.
Posted : 25/06/2017 8:22 pm
Have 105 hydros and for the most part they're great. Very smooth. I actually like the ergonomics and increased size. Stopping power isn't really any different to rim brakes, when on the standard pads in the dry.
Only downside for me is:
- Weight.
- The horrendous squeal I have!
There's something quite nice about rim brakes in the dry I think. And discs aren't the game changer that they were in MTBing. But nice to have on an all-weather bike.
Posted : 25/06/2017 8:28 pm
 igm
Interesting. Same brakes on my CAADX that I use for commuting. Now it does have 40mm tyres and panniers weighing down the rear but it's ridiculously predictable.
Posted : 25/06/2017 8:30 pm
SRAM Rival hydro disc on CX bike.
Shimano/Giant hybrid hydro on the commuter.
Carbon rims and rim brakes on summer bike.
Just bought another expensive 'summer' road bike - with rim brakes.
They all do their jobs well - discs are better in crap conditions but rim brakes are just as good in the dry, lighter and more aesthetically pleasing on a skinny minimalist road bike.
I'd be pretty damn sure it's the same calliper, pad, fluid, hose, rotor, bolts etc. And in case you missed it, I'm not riding it off-road, it's being used almost entirely on tarmac, with 29er wheels fitted with 38c slicks, so like any modern gravel/road bike. Other than that though, good point 🙄
Anyway, I'm obviously still in a minority and JamieP has rightly called me up for my confirmation bias ignoring the other happy SRAM users
Posted : 25/06/2017 8:34 pm
 Ewan
I have the 105s wouldn't buy a bike without them.
Posted : 25/06/2017 8:44 pm
Been playing with this, apart from the uncomfortable levers the brakes are great, modulation is good , as it stopping power. only used in the dry so far so no real advantage over a good set of rim brakes, in fact i'd say they were on a par with a set of Ultegra rim brakes
Posted : 25/06/2017 8:46 pm
Not massively convinced. They're good when I'm pressing the bike into off road service. A bit squealy and nasty on the road. Pad wear is about 40% from normal braking, and the other 60% from pre-braking to avoid howling rotors, and bedding in new pads. This last set of front pads squealed all the way until there was only a slither of material left, and now they're as good as gold. All genuine Shimano kit.
The major drawback of road disks is that they ocassionally shreik fit to wake the dead. Both my TRP Hy/Rd and non-series Ultegra have done so.
My theory (feel free to shoot it down): 1. roads spray up all sorts of contaminated oily crap onto your rotors. Mountains spray up only good healthy gritty mud. 2. MTB steep and twisty means one puts a hell of a lot more heat through your brakes, this further keeps them clean and quiet. Road biking by contrast involves not nearly so much braking, so one doesn't routinely get the heat build up which would burn off the badness.
The result of 1 and 2 is that MTB disk brakes are nice and quiet, but road disk brakes are max shreik.
Just a theory.
Posted : 25/06/2017 8:53 pm
 igm
Crimsond - you may be right. Get round it by breaking really really late. 28mm tyres might help.
Posted : 25/06/2017 9:23 pm
My 105 brakes suffer from squeal, but a good clean of the rotors and sand/gas hob session on the pads seems like it sorts it out.
Posted : 26/06/2017 12:20 am
Even in the dry I find they offer way more power than rim brakes. I was on my rim braked bike today, you do adjust to it, but there's noticeably less power available.
Yes, but the levers are different. Every member on this forum can proffer an opinion on MTB discs, but the feel of them comes more or less entirely from the levers.
FWIW I've got RS785 Di2 STIs on the disc bike and find they feel nearly identical to the 9070 STIs on the 'nice' bike and the 6900s on the turbo bike. No issues with hoses sticking out or hood shape being odd
Posted : 26/06/2017 3:28 am
I have four road bikes, three disc and one rim brake.
The RS785 Di2 STI on my synapse are nice but feel inconsistent and a long lever pull before anything happens.
Hoods shape is ok, I can use it but probably my least favourite.
Cx1 force, far more consistent than the 785s. Nice solid lever feel and very easy to modulate.
I hate the look of the hoods but they're super comfy to use. Have these on the gravel bike and have done some major descending without issue. ( 1400 meters over 5k )
Another bikes has force 22 levers with SPyres. I still really like theses and would use again. Easy to set up and plenty powerful. A step up from rim brakes.
Th best brakes I have are ultegra callipers with black prince pads on Reynolds assault carbon rims. In the dry they are stupidly powerful BUT, and here is the BUT.
Where I live they I risk overheating the rims and in the wet they are more than puckering when they don't bite.
If I could only have one, it would be the force cx1
Posted : 26/06/2017 7:47 am
I'm inclined to agree. I went to the Vosges over the weekend and descending I would have preferred to have the disc bike but that was only on one descent which was all switchbacks (the other "swoopy" ones, I couldn't have cared less). The ultegra rim brakes are good but not QUITE as good. Going uphill I was happier with the rim one as it's both lighter and has a bigger cassette.
Posted : 26/06/2017 8:07 am
Granted, but I wasn't commenting on feel, I was commenting on other aspects of the performance (squeel, noise, calliper misalignment etc.) that aren't really affected by the lever, so it seemed like a valid comparison.
CrimsonD's point above probably applies to me though, I've always been a light braker (I do lots of braking, just well in advance and lightly feathering rather than hauling on at the last minute) so perhaps discs will never really work on the road for me, or I should just use 140mm rotors all round to get some heat in them (at 85kg... 😯 )
Posted : 26/06/2017 8:33 am
I'm off to the Alps in September and still can't really decide which bike to take. The rim brake bike is 'nicer'; Dura Ace not Ultegra, 4lbs lighter, more comfortable, but I wouldn't really fancy the carbon clinchers on Alpine descents, and I don't think I can overlook how much more fun I'll have descending on the bike with discs.
I've no idea how on and on can find Ultegra calipers on carbon rims to be the best his brakes. I was very happy with the performance of mine until I used discs. I'm still content with them, but to say they out perform discs in any circumstance is lunacy IMO.
Posted : 26/06/2017 11:47 am
I'd agree disc brake better, much more confidence inspiring.
However, as a couple of others have said I couldn't get on with the shape of RS685 and I got rid of them. They do seem to get contaminated and noisy as well, unless you do regularly hard stops or descents.
Just about to build a road bike and it'll have rim brakes (also means I can have a go at racing again)
The biggest disadvantage of rim brakes was the *really* bad performance of long drop calipers which you need for 25mm tyres + 'guards so I'm sticking with standard drop calipers.
If I want discs for commuting I'll stick with a fast hybrid now (lots cheap too and a place for my old MTB bits too!).
Posted : 26/06/2017 11:52 am
Practise your braking technique. I lost count of the number of people I saw with blow outs descending Alpe d'Huez from dragging their brakes on carbon rims. I didn't find any problems descending with caliper brakes in the dry (there's plenty of grip for late braking into the corner) but it would've been a trial in the wet. You'll also have a lot more fun on the way back up on a light bike.
I'd agree with this - having ridden a CX bike on the road with disks recently, it just highlights how truely crap rim brakes are.
I'd not even consider anything but a disk braked road bike now if I was buying one.
Have HY/RD on the tripster. Would be perfectly happy with calipers on road, but that said the weight penalty is worth it for me (only competing with myself) on road also for consistency and lack of maintenance. I'd say nice to have on road, but a real plus off and touring.
That said, just waiting on a swap to Ultegra hydros this week .. can't wait to try them out as the final part of the puzzle!
Posted : 26/06/2017 11:54 am
Njee20
While your in the alps , feel free to pop by and try the bikes if you like 🙂
If you're doing consistent big stops, you'd be mad not to take the disc bike.
In the dry the rim brakes do stop harder than the discs - maybe my technique is driven by the paranoia that I'll over heat the rim brakes so hit them harder and drag the disc a little more.
Posted : 26/06/2017 11:59 am
Happy with my technique, I'm not a brake dragger, and have never actually had problems with carbon clinchers, just know I'd be more tentative on a long descent versus discs.
So they perform differently because you treat them differently...? That's like saying mechanical shifting performs better because I let Di2 go flat. The discs have the ability to stop 'harder', whether you exploit that is something else entirely.
We're staying in Bourg d'Oisans - if you're local then a guide would be marvellous for a day! I'll have a chance of keeping up with a local if I've got discs 😉
Posted : 26/06/2017 12:17 pm
wilburt - Member
Wins the thread.
I run hy-rds on the commuter. It's fine, but I did have a strange problem with gunk running down the back of the fork leg and into the caliper, which gave me truly horrendous pad life (~100 miles) in poor weather (and short intervals between adjustments on the previous all mechanical setup - no brakes by the time I arrived at work).
TL:DR - they're reliable and low maintenance now, but they weren't for a while. I have at least as much power available in the dry on my other road bike, if you're getting inadequate braking in the dry from rim brakes I'd suggest you find out what's wrong with them. Cables (and pivots) can end up full of crap and affect performance.
Posted : 26/06/2017 12:23 pm
I need new wheels for my rim braked road bike, because I've worn out the rear wheels rim in around 8000Km of use.
I've also had a rear rim fail on the brake trak during a long tour.
this indicates I drag the back brake far too much; but I'm also loath to spend loads of money on a wheel set that'll need binned because I'm a jessie on the descents, when it could be a 30 quid rotor instead. (oh and brake pad life, I've just after 5000ish km changed the organic disc pads on my disc shod road bike (mostly used in winter rain); I think I had gone through 3 sets of rear and 1 set of front pads in that distance on the rim braked bike (mostly used in summer rain).
that said, sod buying a disc braked bike until things have calmed down and mavic know what to put on their neutral service cars (as this indicates an axle standard has been argued over and 3 are in use rather than 6)
Posted : 26/06/2017 3:24 pm
"until things have calmed down"...?
QR axles then.
£5 says i can still buy new QR hubs in 10 years, i won't make the same bet with boost, 100x12 (or whatever), etc.
Posted : 26/06/2017 4:07 pm
