Road content, carbo...
[Closed] Road content, carbon bars carbon stem problem
[#6945870]
Hi I know its not mtb but im sure someone will know the cure.
Ive just fitted a carbon stem and bar and torqued the bolts correctly but the barturns in the stem. Its a 4 bolt faceplate and even with them torqued 1 lbs/ft tighter its still happening. Why?
Cheers Naffa
Posted : 20/03/2015 6:17 pm
Carbon fit paste...
Posted : 20/03/2015 6:22 pm
What bars and stem ? Are they chinese fakes ?
Posted : 20/03/2015 6:27 pm
How loose?
Posted : 20/03/2015 6:37 pm
They arent loose at all its just when putting weight on them when stationary they move downward.
Posted : 20/03/2015 8:49 pm
Right size bars for stem?
Posted : 20/03/2015 8:53 pm
 hora
Carbon paste?! So at 30mph you used paste to torque high enough?
Get a second (mechanics) opinion IMO.
Posted : 20/03/2015 8:55 pm
Thanks ppl. I'll get some carbon paste. Can you recommend an online supplier?
Posted : 20/03/2015 9:29 pm
Crc are as good as any for carbon paste.
Posted : 20/03/2015 9:31 pm
Carbon paste isn't the answer, that's not right. It's not structural!
Are bar and stem the same brand?
Posted : 20/03/2015 9:37 pm
 hora
Get a second opinion. The answer could be staring you in the face. Its controls. You need to be sure.
Posted : 20/03/2015 9:41 pm
Either the bolts are tight, or they're not. So unless your torque wrench is out of spec (entirely possible), I'm not sure what a second opinion will bring...
Posted : 20/03/2015 10:09 pm
 hora
Experience.
Last weekend. Two of us couldnt figure out why his headset was loose (Ive fitted...loads).
Third rider pointed out the bloody obvious.
Posted : 20/03/2015 10:11 pm
Experience to say "ah yes, those bolts you've torqued...? You haven't". 😕
Headset's a bit different. Slightly more going on. Still want to know if they 'match'.
Posted : 20/03/2015 10:16 pm
