Road clipless pedal...
[Closed] Road clipless pedals, shimano, Look or?
[#6438318]
I've got a pair of road shoes, just trying to decide on what pedals to use with them, price is a factor here.
R540s seem the obvious choice but I am also thinking it might be interesting to try look or even one of the cheap LOOK compatible pedals knocking about ("Exustar")...
I don't make speedplay money...
Any useful suggestions?
Posted : 25/08/2014 6:49 pm
There was a post earlier about r540's with cleats for £19. Can't think of any good reason to try anything else.
Posted : 25/08/2014 6:56 pm
The exustar ones are fine, plenty of people i know use them daily on commuters and have way less issues that most others and being compatible with look cleats make it easy to get replacements.
Posted : 25/08/2014 7:12 pm
Those r540 are sold out but you can get a pair of shimano with cleats forunder ~£25, then again you can get other brands of "look compatible" jobs for less and pukka keo for ~£30.
It's a fiver each way so really I guess I'm looking for people with experiences of the different pedal systems to offer their input, is float an advantage of one over the other?
Posted : 25/08/2014 7:20 pm
The shimano ones come with a cleat that has some float, I bought some because at the time they were cheaper than the exustar ones
but bear in mind that you don't need as much on a road bike as you're not flinging it around like you would a mountain bike.
Posted : 25/08/2014 8:23 pm
I've use the look knock off's too, apart form being heavy they're fine.
Having said that shimano are far far better, look pedals wear out way too quickly. R550's have a metal plate under the cleat which stops the pedals wearing out, don't think the r540 has that so they won't last as long and the R550's are usually <£30 anyway.
Posted : 25/08/2014 8:26 pm
Shimano, easier to clip in, harder wearing cleats, slightly lighter base models.
This from a KEO Blade user of 10 years. If I started again, I'd probably go with Shimano.
Posted : 25/08/2014 8:32 pm
Yeah 9 degrees did sounds like a lot, buts then there's 4.5 an 0 degree look cleats and shimano offer 6/2/0 degree options.
I guess I could start off with the cheapest and floatiest option (Exustar) and if I find it too much either opt for new cleats or switch to shimano...
I was expecting to be told Exustar simply fall apart, doesn't matter too much if they are a bit heavy TBH, I can live with a few more grams.
Cheers all.
Posted : 25/08/2014 8:39 pm
I bought some shimano 550s from CRC for about £28 recently (because of the metal baseplate as Tina S suggests - no idea if it really makes a difference though)
They're fine for me, particularly in terms of float (was on speedplay frogs before, using mtb shoes, because of old-man knees)
Posted : 25/08/2014 8:40 pm
I'd go Shimano. R550s are nicer than the R540s - they have the wider platform of Shimano's higher end pedals and are a chunk lighter.
Posted : 25/08/2014 8:44 pm
