Im looking at buying a road bike to commute on but am not sure how to size them up for correct fit.
Im 6foot2 and ride an xl turner.
What sort of size roadbike should I be looking at and how can I tell if it fits correctly or not?
STEVE
Most of the websites from the biggies have size charts.
Should narrow down the choice at least?
Go and sit on a few, ask LBS?
Loads of complex fitting guides available but you can't beat just slinging a leg over one.
Thanks for the reply.
I've not really sat on a road Bike so nit sure how they are meant to fit.
Plus was really looking secondhand so can't really throw a leg over one?
I'm 6"2 and ride a M/L giant TCR 2, think that equates ~56cm in normal sizes. I usually ride a 19" HT.
I'm a long legged 6'1" and ride a 56cm Specialized
My MTB's are 19in
a 6'2 you'd be in 58cm territory. depends on how you like your bikes, I've always ridden the road as well as mtb so I like a long top tube, I have an XL Anthem 29 with a 110mm negative stem and a size L TCR Advanced with a 135mm 0 deg stem if that helps any.
Personally I'd say unless you've got really short arms/torso a 56 is too short.
Snap, I'm just over 6 foot and ride a 56cm (effective top tube) - compact geometry, I also ride a 55cm traditional geometry frame (long legs - short torso).
Would still recommend going and slinging a leg over a few, perhaps even hire one to try?
58/60
All depends on inside leg & arm measurements.
Im 6' 3" with a 34 / 35" inside leg, average arm length.
Even after a trip to my lbs, I opted to go against what they suggested (58cm) & ended up with a 61cm.
I can honestly say im glad I did - the bike is unbelievably comfortable (Specialized Roubaix)
I found this pretty helpful when i was looking
http://www.competitivecyclist.com/Store/catalog/fitCalculatorBike.jsp
Typically, 58cm or less (depending on your flexibility, size of your belly, leg and arm length etc)
There's loads of adjustment in saddle/stem/bar position though, so don't wont to much.
If you're unsure, err on the side of caution and go with a smaller size. There's nothing worse than a road bike that's to big for you as you'll end up with your bars as high as your saddle, a short stem and your saddle all the way forward to make it fit.
But, if it's just for commuting, what about a hybrid?
I've got a 58cm/XL Scott CR1 and am just a bit shorter than you; I was 6'2" but seem to have lost an inch in middle-age...
Renton; you're at Leuchars now..? Welcome round (fifteen minute drive) if you want to come and have a sit on it.
56/58 and possibly 60 depending on limb lengths and riding style. really important to try a few before spending too much, although bikes bought second hand on ebay can usually be sold second hand on ebay at not too much of a loss...
Househusband .... I will take you up on that offer when I get back off this course I'm on in the UK!!
Had thought aboit a hybrid, I've got a carrera subway with 26 inch wheels at the moment and I'm finding it very uncomfortable and cramped compared to my 5 spot! The subway is a 21 inch frame to but visually looks a lot smaller than the spot!
I may also look at a rigid 29er with slicks to see if that's any better!
What hybrids are there aboit?
