Road bike cassette/...
[Closed] Road bike cassette/wheel/campag/shimano quandry,possible numpty content
[#4246239]
hi all,very new to road biking and enjoying it so far,but i want to swap the wheels as the noise from the pro 3 hub is not for me,
the bike is equipped with campag centaur shifters and f+r mechs,
i've looked at the cassette and it has no name/number or any other markings on it so i don't know if it's a shimano or campagnola cassette,am i right in assuming that the cassette must also be campag?and the hope/mavic wheels are a campag freehub?
if i order a new set of wheels do i have to order them with a campag fitting to go with the mechs/shifters?
the wheels im after are only available with a shimano fitting at present,being new to compatibility issues(unlike good ol m.t.b's),as left me a bit wary as to what works with what on road bikes,
thanks in advance for any help/advice you may be able to offer,
gray.
p.s the bike was second hand
Posted : 10/08/2012 5:44 pm
Campag cassettes have slightly different spacing to shimano. The splines are different aswell, so you'll need a campag specific free hub body on your wheel set.
Posted : 10/08/2012 5:56 pm
You can get expensive third party cassettes that fit Campagnolo spacing on Shimano hubs but the easiest thing to do is stick with Campagnolo free hub / cassette. On most mavic wheels you can switch free hub from Campagnolo to shimano
Posted : 10/08/2012 6:18 pm
You're talking about a road bike here, so there's a much simpler solution. Keep pedalling. That way the noise from the freehub won't bother you.
Posted : 10/08/2012 6:42 pm
As aracer say, just keep pedalling, your on a road bike, not an MTB, and you shouldn't be freewheeling.
As for what cassette to have, mixing Shimano & Campagnolo can be done, but it is always a messy solution, and just sticking with one system is the best solution.
With wheels from Fulcrum, American Classics and a few others you can swap the freehubs from Shimano to Campagnolo, and you can buy some cassettes with Shimano splines & Campagnolo spacing (Ambrosio), but which ever way you do it, it will almost always cost more than just getting the regular Campagnolo parts in the first place
Posted : 10/08/2012 7:03 pm
The shifting is rubbish on these. There's plenty of good wheels available with Campag freehubs.
Posted : 10/08/2012 7:24 pm
well lads you did'nt let me down, had a feeling i'd get a bit of advice on the subject of freewheeling!! tbh i'm doing my best to keep "dancing" but i do like to stop and look at the scenery every once in a while and here the birdys doing thier thing plus i need to slow down and f.w to scowl/snarl at friendly mtb er's!,thanks for the helpful advice though people,as always it's genuinely appreciated and will no doubt save me from self inflicted aggro.
Posted : 10/08/2012 7:29 pm
If you have Campag shifter the cassette will be hence the need to get compatible hubs. You can get decent cassettes than fit Shimano splined hubs. The American classic one I had was perfect. I have fitted a Ambrosio one which is much cheaper and to be honest I can't fault it. With older Veloce shifters its shifts sweeter than my mates brand new Centuar set up. maybe there is a set up issue there but its fine by me.
Posted : 10/08/2012 8:36 pm
If your able to remove the cassette and post a pic it might be easier to tell what type the freehub/cassette is. It's a surprise there are no markings. for a campag cassette the longest notch has step in it about half way . Shimano's long notch is the same size.
As Matt says it's most likely campag if yor using campag shifters. It is possible to run 10 speed Campag with a shimano cassette though.
If your buying mavic wheels the freehub can be swapped as they do both. Same's probably true for fulcrum wheels.
Posted : 10/08/2012 8:46 pm
So either stop, or learn to soft pedal - a useful thing to be able to do. There really is very little need to freewheel on a road bike. Excessive noise from a freewheel is a really silly reason to change your wheels or mess around with them on a road bike.
Posted : 10/08/2012 9:19 pm
Ambrosio do one for £30. They don't shift quite as well but they're perfectly functional and useable
Posted : 10/08/2012 9:33 pm
