Road 10 sp shifters...
[Closed] Road 10 sp shifters with a 9 speed mtb mech?
[#6420568]
Looking to add some lower gears to a compact setup. Will a 9 speed mtb mech work with 10 speed road shifters and are the 10 speed cassettes the same for road and mtb? Ta
Posted : 17/08/2014 7:59 pm
Yes for shifters. Road cassettes are 1mm narrower, Shimano alleged there were compatibility issues, but never seen any problems whatsoever. So, to all intents and purposes, yes.
Posted : 17/08/2014 8:05 pm
AS njee says
I've done it and it works just fine - not even any snags at the extremes of the cassette (ran a bike 1x10 for a while, so used lots of either end)
Posted : 17/08/2014 8:14 pm
My BIL just showed me his Dirty Disco with 105 10spd Brifters, Deore 9 speed non-shadow mech & 10spd 11-36 block. Worked a treat!
Perfect! Thanks very much all. 😀
Posted : 17/08/2014 8:15 pm
Works for me Geoff. I have an XT cassette on the tourer
Posted : 17/08/2014 8:40 pm
and do I need a long cage if only running a double compact or can I get away with a medium cage?
Looking at this http://www.wiggle.co.uk/shimano-xt-m771-9-speed-rear-derailleur/ with an 11-36 block
Ta
Posted : 17/08/2014 8:48 pm
Two people tonight have now used the term 'brifters'. I insist that no one ever uses it again, horrendous term
Medium cage will be fine!
Posted : 17/08/2014 8:50 pm
Medium cage only has a capacity of 35T, so long cage needed?
(50-34 plus 36-11 equals 41T)
Posted : 17/08/2014 8:52 pm
Long cage it is then!
Posted : 17/08/2014 9:02 pm
Arse, yes, sorry, I'm thinking MTB gaps. It would probably work, but I'd go long to be sure.
I've done it with a short cage but that was 11-32 so prob. best going long.
Sometimes it can over-shift very sightly, even with all stock items. Not sure why as sometimes it's bob on. I've had to re-position the cable on the rear mech a few times to stop the overshifting, so just keep an eye out for that.
Posted : 17/08/2014 10:00 pm
Ultegra 10sp STIs working with a 10sp 12-30 Ultegra cassette and a 9sp XTR medium cage rear mech on my CX bike, works fine.
Next thing is to try it with a 12-36 XT cassette for the Three Peaks.
Also, I agree with njee20 on use of the term "brifter". Use of that demands immediate death by firing squad.
Posted : 17/08/2014 10:10 pm
