Ritchey Torque Key ...
[Closed] Ritchey Torque Key - handy little tool indeed !
[#3675760]
one of these arrived this morning :
[url= http://www.ritcheylogic.com/dyn_prod.php?p=05-252-100 ]ritchey[/url]
with the idea of popping into back pocket when on new bike so I can fettle with carbon things.
first impressions are it's a clever wee thing. A quick check against my bigger torque wrench suggests it is about the same 5NM as the other one 😆 although initially I though it was more than 5NM to click off because the small handle giver a very short 'lever'
Posted : 14/02/2012 12:34 pm
cost?
Posted : 14/02/2012 12:37 pm
I've just got one too - they're ace! Especially when putting a carbon post in a carbon frame! Whats scary is when you put a normal allen key on the bolt afterwards and feel how loose it is - I've been properly over-tightening stuff!
Posted : 14/02/2012 12:38 pm
SuperStars one is better, you can change the bits...
Posted : 14/02/2012 1:10 pm
sorry, been out all day - was about a tenner. Changing the bits could be handy, but I suppose stem bolts are pretty much the same size (or at least on my bikes they are (and same as seatpost on roadbike !)
Posted : 14/02/2012 9:18 pm
Some people have managed to change the bits on them, mine seems stuck fast but irrespective it's a handy little bit of kit, accurate too.
Posted : 14/02/2012 9:29 pm
There's two versions. One is fixed, the other comes with spare bits. 5mm, T25, 4mm and a couple of others I think.
Posted : 14/02/2012 9:36 pm
 br
[i]SuperStars one is better, you can change the bits... [/i]
But you can on the Ritchey one too, at least on mine (about 2 yrs old).
Posted : 14/02/2012 9:38 pm
+1 awesome little bit of kit.
As others have said their seem to be 2 versions , one where you can't change the hex key to a different size and one where it's movable. I think the Supastar one is changeable. Either way great tool.
Having used the ritchey tool, I went and bought a full torque wrench set.
Posted : 14/02/2012 9:43 pm
