Riser bars with onl...
[Closed] Riser bars with only one direction of sweep
[#9674709]
What riser bars can you get with only back sweep and no up sweep?
I only want one bend like you have with a flat bar, but I need more height and there aren't that many 800mm flat bars.Is the only way to achieve this flat bars with a higher stem?
I found these custom ones that you can decide how much sweep.
https://www.sevencycles.com/accessories/titanium-riser-handlebar.php
Posted : 18/11/2017 5:39 pm
I think that riser bar manufacturers cite upsweep and backsweep on the assumption that the bars are set in the stem with the "riser" part of the bend in the vertical plane.
All you have to do to get backsweep only is rotate them backwards from that position by the quoted upsweep figure. They will look a bit odd I suppose, but it is generally only a few degrees.
ETA riser bars are always going to have to have two bends in them otherwise they would be flat
Posted : 18/11/2017 5:45 pm
A bar with only one bend is a flat bar. It makes no functional difference whether you achieve the rise through the stem or by adding another bend to the bars.
Posted : 19/11/2017 1:44 am
15/20mm low rise no good?
Posted : 19/11/2017 9:39 am
I got some of these [url= http://www.chainreactioncycles.com/mobile/funn-full-on-riser-bar/rp-prod91525?gs=1&utm_source=google&utm_term=&utm_campaign=Chain+Reaction-UK-PLA-PLA-All-MB-SE-Shopping+QLB+Manufacturer+Mobile&utm_medium=base&utm_content=mkwid|sDPh8WxdM_dm|pcrid|161810673982|pkw||pmt||prd|351785UK ]Funn full on in 810mm 7' rise[/url] which essentially feel like a flat bar to me.*
* I could have missed the point totally to your question, as I'm fundamentally a roadie with an MTB.
Posted : 19/11/2017 10:28 am
argh, non working image tag.
Oh well, insert ‘Stonehenge’ picture of choice...
Posted : 19/11/2017 10:37 am
http://www.chainreactioncycles.com/3t-riser-740-ltd-mtb-handlebar/rp-prod133739
Ignore the answer that says they have 9deg upsweep. They don't
Posted : 19/11/2017 8:33 pm
