Warranty I hope? You're lucky you don't break more kit, lightweight weenie whore.
helicoil?
What size rotors where you using?
Warranty I doubt it. I think a 23ish lbs IF can't be described as a lightweight weenie as it only gets used for XC type stuff anyhow!
Helicoil? No its a cracked frame 🙁
Rotor using Juicy Carbons with a 160mm Marta Sl rotor
love the springer pics in your flikr...
nice local garage blobby weld would fix that
That should be an easy weld repair. Find a local fabricators and give them a crate of beer. Otherwise just call K!
I'd offer to do it but my welding is amateur!
It will be fixed either by IF themselves or Argos in Brizzol, its too much of a good frame just to get it bodged!
nasty one, good luck dude
if it was a real IF, it wouldnt have failed, even with you riding it
Bummer.....but if you will go off drops!
Drops? I rode round most of them LOL and the ones I did where barely steps!
I'm thinking about hiring myself out to frame builders next year as a tester 😀
Ahh, that's not broke. Easily mendable
is it fixed yet?
a year on, one would hope so!
Got a new one!
christ i thought youd broke another then mate 🙂
Fatnackerinbrokenframeshocker.
