Rims - I'm so ...
[Closed] Rims - I'm so confused.
[#5623904]
I would like some new kinda light, reasonably strong, not too expensive wheels. Choosing hubs seems easy, but I've no idea which rims are best. The bike is a BFe and I consider myself an "All Mountain rider". Not racing or xc, not flat out downhill or 6 foot drops, but I do like my smallish 2-3' drops and downhill trails (at a reasonably slow pace). I tend to run 2.35 High Rollers and I weigh 14 stone.
I figure Mavic 719 rims are what I need. But what are the equivalent Stan's rims? I don't intend to run tubeless - are there Stan's rims hard to get normal tyres onto? Are they much lighter than the Mavic's?
All in out much appreciated.
Posted : 21/10/2013 11:47 pm
I've got flow rims and there bad ass, don't weight loads, strong as you like and tyres glide on and off(at least schwalbe and continental).
Hope that helps
Posted : 21/10/2013 11:54 pm
Having used Mavics for years Stans are a bit of a revelation. I love how wide they are, they seem to be a bit stronger and a bit lighter, and if you're running tubeless they make it really easy to inflate your tyre. The equivalent to a 719 would be an Arch.
Posted : 22/10/2013 12:12 am
hi,
Go for SSC Sentiniel or Tactic. For the money they are ACE!!!
Cheers!
I.
Posted : 22/10/2013 3:10 am
arch ex.
look [img] [/img]
and I weigh 100kg and ride like a bag of spuds.
Posted : 22/10/2013 4:04 am
Flow ex. They make a great build.
Easy to go tubeless should you ever want to.
Posted : 22/10/2013 5:20 am
I have a Hope build on Mavic XM719's it's a custom build from my LBS.
They are strong, light and still true. Tubless was a piece of cake, only needing valves and yellow tape to go up. Width wise they hold a nice shape on Minion 2.35's, HRII's and Ardent's.
Posted : 22/10/2013 5:42 am
Similar wheel and riding situation I was in a few weeks ago and I ended up with mavic sx wheels but while looking I took width and tubless into consideration, i'd moved from zesty to slackline. Extra width provides the better footprint and I can run a lower tyre pressures which softens things out, which I need 🙂
Posted : 22/10/2013 6:21 am
