Rim tape size
[Closed] Rim tape size
[#5369292]
Setting up some mavic crossride wheels tubeless later what size tape do I need.
Posted : 27/07/2013 7:19 am
From personal experience with XM719's (same rim) I would recommend using stans standard rim strips rather than just tape as the tyres are a loose fit on the bead benches and you will struggle to get them inflated. If you want to have a go with just tape then you want some 21mm wide stuff as the rims are 19mm wide and you'll lose a bit of width as it follows the profile of the rim.
Posted : 27/07/2013 6:39 pm
